2 Replies Latest reply on Mar 7, 2015 3:12 AM by Laubender
    for cs 6 flexible width command
    hamdifem Level 1
      I'm appointed to command
      I want to give flexible width of the text frame
        • 1. Re: for cs 6 flexible width command
          Text frames are flexible (unless they are locked), so I presume you are requesting a script that resizes a text frame while typing. I don't believe that is possible with scripting.
          • 2. Re: for cs 6 flexible width command
            Hm, that should be possible with an eventlistener on the app object listening for AFTER_SELECTION_CHANGED events by filtering out the one text frame you are typing in. The problem would be how to tell InDesign to stop the behavior, to stop the function that is doing the change on the text frame. For that you need a second script.
            But why not using the flexible text frame options that come with the textFramePreferences? Namely:
            autoSizingReferencePoint
            autoSizingType
            Uwe
            //EDITED
