2 Replies Latest reply on Feb 19, 2007 7:50 AM by Walter Elias
    bending images
    Level 7
      how do i bend an image in flash i really cant figure it out
      cheers warby
        • 1. Re: bending images
          Level 7
          you can't - flash does not have an image warp feature - you would have to do 1 of 2 things:
          Trace Bitmap the image to convert it to vectors - then use Free transform tool > Envelope or Distort
          tools.
          OR
          Bend the image in P'shop and then import into flash.
          If you need to bend the image as an animation - then flash is not your tool - i would highly
          recommend Animae Studio (www.e-frontier.com) for this (I use it all the time). It supports IK
          (Bones) and Image Warp - then export as Quicktime and Import into flash.
          hope this helps
          --> Adobe Certified Expert
          --> www.mudbubble.com
          --> www.keyframer.com
          > cheers warby
          • 2. bending images
            Walter Elias Level 2
            You can bend and warp vector images with The Tab (www.the-tab.com), and export them as Flash movies. It also has several effects borrowed from Illustrator and from higher end animation programs that are not available in Flash, such as textured lines. It's a very cool animation program, though the interface is very different than anything you're used to.
