0 Replies Latest reply on Feb 20, 2007 12:32 PM by DARAB
    Cell render breaks when grid is resorted
    DARAB
      I'm using a 4-button cell renderer in the Macromedia Devnet enhanced datagrid. I have column sorting turned on for many of the colunms. Cell rendering works fine until I click on a column title and resort the grid. When I select a radio button, the radio button I select appears not to be selected as soon as I move my cursor off of it. It doesn't matter which column I sort by or if it is sorted in ascending or descending order.
      If I resort the grid in its original order, the cell render works fine again and any radio button selected after resorting now appears selected, if though they did not appear to be selected after a resort.
      I have turned of the ability to resort the grid which has irritated my customers.
      I'm using Flash 8 and the latest Flash Player.
      Here is my cell renderer's code:
      import mx.core.UIComponent
      import mx.controls.RadioButton
      class CR_Progress_Statuses extends UIComponent
      private var radioTotal:Number = 4;
      private var radioWidth:Number = 20;//55
      private var startX:Number = 67;
      private var deltaX:Number = 2;
      private var contentWidth:Number;
      private var radios:Array;
      var owner; // The row that contains this cell
      var listOwner : MovieClip; // the reference we receive to the list
      var getCellIndex : Function; // the function we receive from the list
      var getDataLabel : Function; // the function we receive from the list
      function RatingRadioRenderer()
      function init(Void):Void
      super.init();
      contentWidth = 230;
      radios = new Array();
      function createChildren(Void):Void
      var groupName:String = "Status_rdogrp";
      var radio:RadioButton;
      radio = mx.controls.RadioButton(createObject("RadioButton", "Planned", 1));
      radio.label = "";
      radio.data = "1";
      radio.groupName = groupName;
      radio.labelPlacement = "left";
      radios.push(radio);
      radio = mx.controls.RadioButton(createObject("RadioButton", "Presented", 2));
      radio.label = "";
      radio.data = "2";
      radios.push(radio);
      radio = mx.controls.RadioButton(createObject("RadioButton", "Practiced", 3));
      radio.label = "";
      radio.data = "3";
      radios.push(radio);
      radio = mx.controls.RadioButton(createObject("RadioButton", "Mastered", 4));
      radio.label = "";
      radio.data = "4";
      radios.push(radio);
      // Listener sur le group pour prendre en compte
      // les touches (droite, gauche)
      var g = radio._parent[groupName];
      g.addEventListener("click", this);
      function size(Void):Void
      doLayout();
      function doLayout(Void):Void
      var w:Number = __width;
      var h:Number = __height;
      var x:Number = (__width - contentWidth) / 2;
      x += startX;
      // 12 : minimal value for radio height
      for (var i:Number = 0; i < radioTotal; i++)
      var radio = radios ;
      radio.setSize(radioWidth,h);
      radio._x = x;
      radio._y = (__height-12)/2;
      x += radioWidth+deltaX;
      function setValue(value:String, item:Object, sel:Boolean):Void
      if (item == undefined)
      var radio = radios
      radio._visible = false;
      return;
      var selectedRadio = null;
      var noValue:Boolean = true;
      radio._visible = true;
      if (radio.selected)
      selectedRadio = radio;
      if (radio.data == value)
      if (!radio.selected)
      radio.selected = true;
      noValue = false;
      // Special case for null value (0)
      if (noValue && selectedRadio != null)
      selectedRadio.selected = false;
      function getPreferredHeight(Void):Number
      return 12;
      function click(eventObj:Object):Void
      var target = eventObj.target;
      listOwner.dataProvider.editField(getCellIndex().itemIndex, getDataLabel(), target.selectedData);
      // Select the row of the radio button selected.
      // listOwner.selectedIndex = getCellIndex().itemIndex;
