1 Reply Latest reply on Feb 12, 2007 8:02 AM by kglad
    Macro Substitution?
      I can use sendAndLoad to pull in actionscript code from an external data source and assign it to a variable.
      Is there a way to then execute this code? I am trying to build a framework for several different applications without having to rewrite and re-deploy the swf files each time.
      Thank you,
        • 1. Re: Macro Substitution?
          probably not. some actionscript code can be converted into a string and then resolved by flash into code using array notation (like onPress)
          but key words (like function) and symbols cannot be resolved so you'll need to use a complex system to associated those strings with key words.
