5 Replies Latest reply on Mar 8, 2015 6:14 AM by raypalmer
    Need Help With Check Box count Script
    raypalmer
      Need to count the number of checked boxes. I'm using the script below and its not working. What I'm I doing wrong? It's driving me crazy.
      // document level function to sum named fields
      function Sum(aFieldNames) {
      var sum = 0; // sum of values
      // loop through fields
      for (var i = 0; i < aFieldNames.length; i++) {
      if(!isNaN(this.getField(aFieldNames[i]).value) )
      sum += Number(this.getField(aFieldNames[i]).value);
      return sum;
      } // end of Sum function
      // array of field names sum
      var aCheckBox = new Array('Check Box5', 'Check Box8', 'Check Box11', 'Check Box16', 'Check Box19','Check Box22', 'Check Box25','Check Box28', 'Check Box31', 'Check Box34','Check Box37', 'Check Box40','Check Box43', 'Check Box46', 'Check Box49','Check Box52', 'Check Box55','Check Box58', 'Check Box61', 'Check Box64','Check Box68');
      // sum named fields
      event.value = Sum(aCheckBox);
