6 Replies Latest reply on Mar 8, 2015 2:53 PM by A.T. Romano
    Not recognizing avi files.
    mikeb96779239
      I'm running PE12 on a computer with Windows 8.1. It's not recognizing avi files - says the correct codec is missing. Where can I safely download the necessary codec(s)?
        • 1. Re: Not recognizing avi files.
          A.T. Romano Level 7
          mikeb
          The answer to your question will come from know what the video compression is that is wrapped/contained by the .avi format.
          What kind of .avi files do you have
          AVCHD.avi
          MotionJPEG.avi
          Xvid.avi
          Dvid.avi
          other
          What is the brand/model/settings of the camera recording this video?
          If needed, please download and install the free codec utility named GSpot to get this type of information.
          http://www.headbands.com/gspot/
          We will be watching for your results.
          Thank you.
          ATR
          • 2. Re: Not recognizing avi files.
            mikeb96779239 Level 1
            ATR
                 It's a Samsung NV10 and the manual says it shoots avi files with
            mpeg4 encoding.
                 Thanks for any help you can give.
                 MikeB
            • 3. Re: Not recognizing avi files.
              A.T. Romano Level 7
              MikeB
              Thanks for the additional information.
              If you had said that your Samsung NV10 was recording AVCHD (MPEG4 AVC/H.264) video with that .avi file extension, then that
              would be your problem since Premiere Elements does not support the combo of AVCHD.avi.
              But, your Samsung NV10 specification show the compression as MPEG4 with that .avi file extension. I have a camera that records
              with MPEG4 compression with an .avi file extension and no problems in Premiere Elements (any version).
              Do you have the latest version of QuickTime installed on your computer along with Premiere Elements? If not, please do so.
              You can also go to Publish+Share/Computer/QuickTime (you will need to scroll down the list with the thin scroll bar to the right of the choices under
              Computer) and verify that the QuickTime Presets are there.
              Please review and consider and then we can decide what next which might involve file conversion. But, let us check out the details on the above
              first.
              Thanks.
              ATR
              Add On...your Samsung is not a cell phone, so I do not think that you are involved with variable versus constant frame rate here.
              • 4. Re: Not recognizing avi files.
                ATR,
                     I just downloaded the latest version of Quicktime. I checked the
                scrolldown under Publish/Share you mentioned, but it said "for playback
                of video on a Mac" which doesn't apply to me. Is there something else in
                the presets that may be off?
                     MikeB
                • 5. Re: Not recognizing avi files.
                  A.T. Romano Level 7
                  MikeB
                  Thanks for the update.
                  It might be that your "MPEG4".video may not be the MPEG4.avi that my camera uses and is less likely AVCHD (MPEG4 AVC/H.264).avi that is supported
                  by Premiere Elements.
                  I am wondering if you have DivX.avi.
                  DivX - Wikipedia, the free encyclopedia
                  Could you download and install the free codec utility names GSpot and note what it shows for Video Codec Name Status.
                  Thanks.
                  ATR
                  • 6. Re: Not recognizing avi files.
                    A.T. Romano Level 7
                    MikeB
                    The news seems to be worse than I thought.
                    I found a video sample 640 x 480 @ 29.97 progressive frames per second that was supposed to be from the Samsung NV10.
                    I ran it through MediaInfo, a popular free video and audio properties readout program, and found the video compression shown as
                    XviD which is worst case for Premiere Elements. If you can confirm that with GSpot for your video, then it is conversion time for
                    your video if you want to use it in Premiere Elements.
                    If that is the way things go, then consider free converter...HandBrake or Movie Maker for the H.264.mp4  version to be imported
                    into your Premiere Elements program.
                    https://handbrake.fr/
                    Windows Essentials - Download Windows Live Essentials
                    I will be watching for further developments.
                    ATR
