3 Replies Latest reply on Mar 8, 2015 3:44 PM by A.T. Romano
    Why is my video exporting without any picture?
    kevinm87844084
      I try and export it from elements, but when its done it ends up as an mpeg with audio but no video.  Any help?
        • 1. Re: Why is my video exporting without any picture?
          A.T. Romano Level 7
          kevinm
          What version of Premiere Elements on what computer operating system?
          Are you running the program as Administrator?
          Do you have the latest version of QuickTime installed?
          What are the properties of your source files? What is the description of your export...
          Publish+Share/Computer/MPEG with what preset (default or customized?) or something else for the export?
          Let us start here and then decide what next.
          Thank you.
          ATR
          • 2. Re: Why is my video exporting without any picture?
            kevinm87844084 Level 1
            A.T.
            I am running elements 13 on windows 8.1, I'm not sure about as an admin, I am not too familiar with the program.  The file was playing the way described in windows media player, so I am not sure about quick time.
            FOr the export, I was using what you described, with default.
            Any Ideas?
            • 3. Re: Why is my video exporting without any picture?
              A.T. Romano Level 7
              kevinm
              Thanks for the reply.
              Running as Administrator is important, so let us see if you are.
              If you go to
              Control Panel
              User Accounts and Family Safety
              User Accounts
              Manage Other Accounts
              how many accounts do you see, one or more....are you using the one that reads
              Owner name
              Local Account
              Administrator
              As for QuickTime....please go to Publish+Share/Computer/QuickTime and see if you have Presets for that QuickTime choice.
              You will need to scroll down to QuickTime toward the bottom of the Publish+Share/Computer list. Use the thin scroll bar
              to the right of the choices for that. Look for Presets field. It should contain choice of presets for
              NTSC DV
              NTSC DV 16:9
              PAL DV
              PAL DV 16:9
              HD 1080i25, H.264, AAC 48 kHz
              HD 1080i29.97, H.264, AAC, 48 kHz
              After you select one from the list, you should be the default description for the selected preset.
              If all that happens, then you have QuickTime installed.
              Are the missing pictures only from the export file? Do you see these images before export? If so,
              you may be involved in a Windows 8 issue involving MPEG2 support and Windows Media Player.
              What is your player? If only Windows Media Player, then consider using the VLC player to determine
              if that will work for you video and audio wise.
              http://www.videolan.org/vlc/index.html
              We will be watching for your progress.
              Thanks for the follow ups.
              ATR
