4 Replies Latest reply on Mar 10, 2015 2:21 AM by Vincent-Sweden
    Command in Java for "all opened documents"
    Vincent-Sweden Level 1
      I have a script that needs modification. Thank you all in the forum for helping me design this script from start btw!
      Anyway, this is the script.
      app.findGrepPreferences = app.changeGrepPreferences = null;
      // Change "Condition 1" to name of your condition
      myConditionList = app.activeDocument.conditions.everyItem().getElements();
      for (i=myConditionList.length-1; i>=0; i--)
          if (myConditionList[i].visible == false)
              myConditionList[i].visible = true;
              app.findGrepPreferences.appliedConditions = [myConditionList[i].name] ;
              app.findGrepPreferences.findWhat = ".+";
              myDoc.changeGrep();
              app.activeDocument.conditions.item(myConditionList[i].name).remove();
      I'm looking for a variable that can apply for "all" opened documents rather than the active one only. I'm having difficulty finding the right command.
      BTW, the script removes all hidden text and objects.
        • 1. Re: Command in Java for "all opened documents"
          I've moved your question to the scripting forum....
          • 2. Re: Command in Java for "all opened documents"
            Jump_Over Level 5
            You can call changeGrep() with various targets, i.e. with app.documents.everyItem()
            var
              mTarget = app.documents.everyItem(), //
              myConditionList = mTarget.conditions.everyItem().getElements();
            for (var i=myConditionList.length-1; i>=0; i--)
                    mTarget.changeGrep();
                    myConditionList[i].remove();
            Jarek
            • 3. Re: Command in Java for "all opened documents"
              @Vincent – all opened InDesign documents, saved or not, are:
              app.documents
              You will get an array of all opened documents that you can loop through by:
              var allOpenedDocsArray = app.documents.everyItem().getElements();
              Uwe
              • 4. Re: Command in Java for "all opened documents"
                Programming has never been my strong side. Never understood it properly and probably never will =(. But thank you solving it. The code "JUMO_OVER" wrote, worked like charm. No need to execute the script 10x for 10 documents.
                Pardon me for giving you guys more out headaches, I have two additional scripts that needs revision for the same purpose as above, i.e. able to exceute the scrip for all opened docs, saved or unsaved. I would really appreciated if you guys could help me convert them. I tried it do it on my own own, but I can't get it working... =(
                Delete Empty Frames in active doc
                var myStories = app.activeDocument.stories.everyItem().getElements();
                for (i = myStories.length - 1; i >= 0; i--)
                    var myTextFrames = myStories[i].textContainers;
                    for (j = myTextFrames.length - 1; j >= 0; j--)
                        if (myTextFrames[j].contents == "")
                            myTextFrames[j].remove();
                Delete Empty Pages in active doc
                app.doScript("main()", ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT,"Remove  Blank Pages");
                function main () {
                    if (app.documents.length === 0) {
                        alert ("Please open a document.");
                        return;
                    app.scriptPreferences.enableRedraw = false;
                    removeBlankPages (app.Documents);
                    app.scriptPreferences.enableRedraw = true;
                    function removeBlankPages (doc) {
                        var pages = doc.pages.everyItem().getElements().slice(0);
                        var i = pages.length;
                        while (i-- >1) { // a bit quicker here
                            !pages[i].allPageItems.length && pages[i].remove ();
                        !pages[i].allPageItems.length && pages[i] != doc.pages[-1] && pages[i].remove ()
                BTW, I didn't write them. So they may look quirky in your eyes.
