0 Replies Latest reply on Feb 18, 2007 5:43 PM by aug_designer
    Webcam/Audio Input
    aug_designer
      I am admittedly an amateur at Actionscript, but I'm trying to produce an example of Flash's ability to process video/microphone data as a "jumping off" point for other projects. My problem is:
      I am using some open source to pick up web cam movement and produce a matrix based on such. I have added the code to receive microphone input, which worked in the example (provided at kirupa.com) that I composed on my machine. I am trying to replace the "dot_mc.1=255" value with the microphone activity value (0-100?) yet I am getting a response of "The property being referenced does not have the static attribute." I understand this statement, but I am unsure as how to re-form this statement to accept variable data.
      Here is the code so far:
      import flash.display.*
      import flash.geom.*
      mic = Microphone.get();
      _root.attachAudio(mic);
      mic.setUseEchoSuppression(false);
      function initialize()
      setInterval(this,"snap",100)
      this.createEmptyMovieClip("snap_mc",this.getNextHi ghestDepth())
      snap_mc._x=(Stage.width/2)-(scale*w/2)
      snap_mc._y=(Stage.height/2)-(scale*h/2)
      m=new Matrix()
      m.scale((output._xscale/100),(output._yscale/100))
      now=new BitmapData(w,h)
      rt=new Rectangle(0,0,w,h)
      n=0
      for(x=1;x<w;x+=o)
      for(y=1;y<h;y+=o)
      ++n
      dot_mc=snap_mc.createEmptyMovieClip("dot"+n,n)
      dot_mc._x=x*scale
      dot_mc._y=y*scale
      dot_mc.lineStyle(dblo,0x000000)
      dot_mc.lineTo(0,1)
      function snap()
      var c=0
      now.draw(output,m)
      for(var x=1;x<w;x+=o)
      for(var y=1;y<h;y+=o)
      ++c
      nc=now.getPixel(x,y)
      nr=nc>>16&0xff;
      ng=nc>>8&0xff;
      nb=nc&0xff;
      nl=Math.sqrt(nr*nr + ng*ng + nb*nb)
      bc=before.getPixel(x,y)
      br=bc>>16&0xff;
      bg=bc>>8&0xff
      bb=bc&0xff
      bl=Math.sqrt(br*br + bg*bg + bb*bb)
      d=Math.round(Math.abs(bl-nl))
      dot_mc=snap_mc["dot"+c]
      if(d>tolerance)
      dot_mc.clear()
      dot_mc.l=255
      dot_mc.lineStyle(dblo,255<<8)
      dot_mc.lineTo(0,1)
      dot_mc.onEnterFrame=fadePixel
      updateAfterEvent()
      before=now.clone()
      function fadePixel()
      this.clear()
      this.l-=this._parent._parent.ml
      this.lineStyle(this._parent._parent.dblo,this.l<<8 )
      this.lineTo(0,1)
      if(this.l == 0)
      delete this.onEnterFrame
      Altering the dot_mc value varies the colors of the webcam matrix dots, so I just need the activity level on the microphone to act as the value and perhaps multiply it by 2 (since the dot_mc value can be up to 255).
      Any Ideas on how to repair this?
