6 Replies Latest reply on Mar 17, 2015 7:40 PM by A.T. Romano
    Adobe premiere elements 12
    steveg12577198
      My premiere elements disc will not load onto my computer. It returns to the start screen instead of loading through the wizard.
        • 1. Re: Adobe premiere elements 12
          A.T. Romano Level 7
          steveg
          Is the installation disc seen to be damaged in any way? Is there any remote chance that you are using a Premiere Elements Windows installation disc on a Mac computer or vice versa?
          If none of that applies to you, then consider using the following 12 tryout download from the following web site and inserting your purchased serial number in those files during installation
          Adobe Photoshop Elements 12 Direct Download Links, Premiere too | ProDesignTools
          Be sure to carry out carefully the web site's "Note: Very Important Instructions" in order to avoid an Access Denied message.
          Another possibility is from this Adobe document
          Other downloads
          Same principle - download the tryout installation files for 12 and insert your purchase serial number in those files during installation.
          Decide on the one that works for you. Same end results.
          We will be watching for your progress.
          Thank you.
          ATR
          • 2. Re: Adobe premiere elements 12
            steveg12577198 Level 1
            It takes me to Adobe premiere 13. I can't get twelve.
            Thanks for helping me. What should I do?
            [personal information removed... Mod - https://forums.adobe.com/docs/DOC-3731]
            [This is an open forum, not Adobe support, please do not post personal information]
            [If you are posting using email, please turn your 'sig file' function OFF for posting]
            • 3. Re: Adobe premiere elements 12
              A.T. Romano Level 7
              steveg
              Thanks for the reply. What is happening with 12 from either route?
              If you want 13, in view of the 12 issues, I would suggest that you go the tryout route for 13 until you assure
              its compatibility with your computer operating system and your project goals.
              Adobe ID Provider
              When you decide to buy, you can purchase from Adobe (only sells download) or authorized reseller who typically offers
              the download or the boxed packaging. Boxed packaging has Windows and Mac installation discs. Those downloads are
              specific to the computer operating system to which it is download.
              Please let us know of your progress when your schedule permits.
              Thanks.
              ATR
              • 4. Re: Adobe premiere elements 12
                I bought 12 from National Camera Exchange. I really don't want to have to
                buy more software because 12 isn't working. I'm running Windows 7 and using
                the windows disc.
                Should I take it back to the store?
                Local Realtors putting your best interest first.
                [Continued posting of personal information may result in a LOCKED discussion... Mod]
                • 5. Re: Adobe premiere elements 12
                  A.T. Romano Level 7
                  steveg
                  Thanks for the follow up.
                  I had suggested a look at Premiere Elements 13 for troubleshooting purposes at this time - trying to determine
                  if 13 would work for you whereas 12 would not. I did not intend for you to purchase 13 at this time.
                  But, here is the important matter for you to consider. You have to weigh the uncertainty of the 12 install with the
                  window of opportunity to get a return/refund from the seller. Unless you purchased 12 at an offer you could not refuse,
                  then consider the return/refund. Then evaluate the tryout of 12 or 13 at your leisure (free 30 days). Another factor for 12
                  would be its availability if and when you decide to purchase it again.
                  You can get tryout files for this purpose from
                  for 12 http://prodesigntools.com/photoshop-elements-12-direct-download-links-premiere.html
                  for 13 Adobe Photoshop Elements 13 Direct Download Links, Premiere too | ProDesignTools
                  Please review and consider the above and then you can decide what is in your best interests.
                  After that we can discuss this further.
                  Thank you.
                  ATR
                  • 6. Re: Adobe premiere elements 12
                    A.T. Romano Level 7
                    steveg
                    Add On...in my post numbered 3, there is a link (Adobe ID Provider) which I did not include in the post. I cannot remove it.
                    ATR
