3 Replies Latest reply on Feb 12, 2007 4:13 AM by RobHack
    Coping Files
    RobHack
      Hi I have developed a touch screen presentation which is preinstalled on the kiosks before they are placed in the remote locations.
      I now am developing a "UPDATE" disk that will allow a NON technical person to update the presentation.
      The plan is like this:
      User quits the exsting running presentation by touching a hidden button and selecting "quit"
      Put new CD into drive.
      A autorun runs the projector and the user selects a update button.
      Files are copied from the CD to the Hard drive writing over the exsisting files
      Screen returns a message "Files copied"
      User touches a "OK " button and the pc reboots (the projector is in the "Start" menu so the presentaion starts automaticly after boot)
      The script I need halp with is to copy the files from the CD to the Hard drive. Tried IOXtra but could not get it to work.
      Any help or comments welcome
      Thanks R
        • 1. Re: Coping Files
          Lukewig Level 1
          The script to copy the files from the CD to the Hard drive is the easiest step of the whole system...
          (using BuddyAPI see www.mods.com.au)
          Result = baCopyFile( SourceFile , DestFile , Overwrite )
          There are also functions for copying with progress bar and copying multile files
          -- Luke
          • 2. Re: Coping Files
            Level 7
            You can run a batch file from an autorun.inf file, so if the files are in a
            fixed location you can just use the "DOS" copy command in the .bat file.
            Andrew
            • 3. Re: Coping Files
              RobHack Level 1
              Thanks the Buddy API worked great just what I wanted...
              Thanks also for the suggestion using dos commands...
              RobH
