1 Reply Latest reply on Mar 10, 2015 6:46 AM by WASIL
    Generated PDF is not fillable
    PhilCheckito
      Hello,
      I am trying to merge (with generatePDFOutput2) a XDP and a XML to generate a dynamic PDF with fillable forms via LiveCycle Output ES3. The PDF generation works fine but in the end the generated PDF is just a normal PDF, without dynamic forms.
      All requirements for a dynamic PDF should have been met (like PDF 1.7). Also I checked all RenderOptions and could not locate the problem.
      Some more informations:
      - The XDP was created with LiveCycle Designer ES4.
      - RenderOptions
          - cacheEnabled -> false
          - acrobatVersion -> 'auto',
          - taggedPDF -> false
          - linearizedPDF -> false,
          - debugEnabled -> false,
          - renderAtClient -> 'true',
          - pDFARevisionNumber -> 'Revision_1',
          - pDFAConformance -> 'A'
      Hopefully someone can help me.
      Regards
      Stephan
