8 Replies Latest reply on Jun 19, 2007 10:45 AM by EliteScientist
    2.0.1 Int64, Long BUG!
    EliteScientist Level 1
      I've been having a problem passing 64-bit Integer IDs through a webservice.
      for some odd reason when flex deserializes the Soap Message to an Object, it nearly adds 8 to 10 to the value of each object and some have the same id...
      I've sniffed the network and saw that the webservice was returning the correct value, and I also set the result Type to xml and I can see the correct value...
      But when the result Type is set to object, it totally screws up the 64-bit Integer value.
      What sucks even more is the source code to mx.rpc is not included in the SDK.
      Does anyone know a way around this other than writing a deserializer?
