6 Replies Latest reply on Mar 11, 2015 4:12 PM by Imposturous
    I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
    Imposturous
      The game is a word search game in an advanced lingo book and the lingo code is using [cc] which is coming up as a code fault.  What is wrong or is this use of [cc] obsolete?  And if so, how can it be corrected?  Thank you.
      on getPropertyDescriptionList me
        list = [:]
        -- the text member with the words in it
        addProp list, #pWordSource,[cc]
          [#comment: "Word Source",[cc]
           #format: #text,[cc]
           #default: VOID]
        addProp list, #pEndGameFrame,[cc]
          [#comment: "End Game Frame",[cc]
           #format: #marker,[cc]
           #default: #next]
        return list
      end
        • 1. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
          James Newton, ACP Level 3
          [cc] here stands for "continuation character". Prior to Director 8, this was ¬ and from Director 8 onwards it was \ (immediately followed by a carriage return). Assuming that you are using a 21st century version of Director, this should work for you:
            list = [:]
            addProp list, #pWordSource,\
              [#comment: "Word Source",\
               #format: #text,\
               #default: VOID]
            addProp list, #pEndGameFrame,\
              [#comment: "End Game Frame",\
               #format: #marker,\
               #default: #next]
            return list
          end
          • 2. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
            Imposturous Level 1
            Hello, thanks for that as it cleared that problem but the problem hasn't gone away.  I tried playing with this all day but to no avail.  I'm now getting this error:
            Script Error:  Incorrect behavior initializer.  (Periods are not allowed in symbols)
            [#pWordSource:<void>, #pEndGameFrame: #next]
            The code is now: (and I have no periods in this lingo)
              list = [:]
            #format: #text,\
            #default: VOID]
            [#comment:"End Game Frame",\
            #format: #marker,\
            #default: #next])
              return list
            end
            I tried doing this:
            ([#comment: "Word Source",\
            #format: #text,\
            #default: VOID])
            ([#comment:"End Game Frame",\
            #format: #marker,\
            #default: #next])
            but it produces the same error as above.
            The other error I'm getting is expecting cast member for (but I don't have a cast member with the name pWordSource and I tried putting the actual name of cast member and the cast member number but both didn't work either):
            -- get words from text member
            on getWords me
              text = member(pWordSource).text
            • 3. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
              Imposturous Level 1
              UPDATE:  I put in a different cast member number (as I have 2 sets of text) and it is now working!!!!
              Thank you.
              • 4. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
                Imposturous Level 1
                Hello again
                Unfortunately I'm still getting this error when I press play for this game.  Though the game is working, this error persists coming up whenever I press play in Director 12.  Do you know what the problem can be?  I don't see any periods in the script.  Thank you.
                  list = [:]
                #format: #text,\
                #default: VOID]
                #format: #marker,\
                #default: #next])
                  return list
                end
                • 5. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
                  I have made the following changes:
                  • Replace...
                             #default: VOID]
                         with
                             #default: ""]
                  • Replace...
                            #default: #next])
                         with
                             #default: #next]
                    list = [:]
                  #format: #text,\
                  #default: ""]
                  #format: #marker,\
                  #default: #next]
                    return list
                  end
                  • 6. Re: I am using a book on lingo puzzles and Director 12 doesn't like using [cc] in the code
                    Imposturous Level 1
                    Dear James
                    That small change in the lingo made the error go away.....I'm very grateful.  No errors are coming up now.  Thank you.
