8 Replies Latest reply on Feb 16, 2007 12:45 AM by hwa-jun yu
    need help on openXLib and hiding mouse
    hwa-jun yu Level 1
      Hi everyone
      I'm new to Director programming. I need help on including .dll files to my project. I saw a syntax named "openXLib" on Director MX 2004 Help, but it does not give sufficient example.
      And I've been trying to hide mouse in Director. It was a piece of cake in Flash, but it troubles a lot in Director.
      Can anyone please post a few lines to solve these two problems?
      Thank you
        • 1. Re: need help on openXLib and hiding mouse
          Level 7
          Not sure about openXLib- that seems to be a way to access methods in
          scripting xtras. You would need to create an xtra in order to make use
          of it.
          But as far as hiding the mouse, just do this:
          cursor 200
          to set it back to default,
          cursor 0
          You can have the cursor set player-wide that way, or have it change when
          over certain sprites by setting the cursor property of the sprite
          sprite(1).cursor=280
          That would set the cursor to a finger when the mouse is over sprite(1)
          To see a list of the available cursors, consult the help file under
          "cursor() method"
          • 2. Re: need help on openXLib and hiding mouse
            hwa-jun yu Level 1
            of it.
            Thanks to Newsgroup User for the info with hiding the mouse.
            Now... 1 problem is solved. Thanks again to Newsgroup User. =)
            So, anyone knows about "openXLib" or any else way to include .dll to Director project? Please help. thank you.
            • 3. Re: need help on openXLib and hiding mouse
              Level 7
              "hwa-jun yu" <webforumsuser@macromedia.com> posted in
              macromedia.director.lingo:
              > my
              openXLib is an outdated method of instanciating Director Xtras and should not
              be required anymore. Xtras that do require instanciation typically use the
              new() syntax.
              To access dll files, you might want to look into glue32 or other Xtras. I
              can't seem to get to updatestage.com* to point you to similar Xtras, but you
              can search for them elsewhere if updatestage.com doesn't come up for you.
              * whois record was updated less than an hour ago. Hope they're not gone.
              Mark A. Boyd
              Keep-On-Learnin' :)
              • 4. Re: need help on openXLib and hiding mouse
                hwa-jun yu Level 1
                new() syntax.
                Thanks, Mark.
                So, I need to download a special xtra to include dll files to Director?
                Is there any free xtra with such feature ?
                • 5. Re: need help on openXLib and hiding mouse
                  Level 7
                  > Thanks, Mark.
                  If you need to access the methods in those .dll files with Lingo, yes.
                  Maybe. Have you looked?
                  updatestage.com is online again, but I'm sure the Adobe Director support site
                  lists Xtras somewhere as well.
                  Mark A. Boyd
                  Keep-On-Learnin' :)
                  • 6. Re: need help on openXLib and hiding mouse
                    hwa-jun yu Level 1
                    I've downloaded glue32.. the registered version is a little expensive, isn't it?
                    I'm thinking maybe I can use the free Director XDK to make my own xtra.
                    I've just finished downloading the XDK.
                    Is it difficult to learn the XDK?
                    • 7. Re: need help on openXLib and hiding mouse
                      Level 7
                      There's the spirit!
                      Sorry, I can't help you there as I've never done it.
                      IIRC, there's a mailing list you can join?
                      Probably one of the links on this page:
                      http://www.adobe.com/support/xtras/
                      Mark A. Boyd
                      Keep-On-Learnin' :)
                      • 8. Re: need help on openXLib and hiding mouse
                        hwa-jun yu Level 1
                        Thanks for both Mike and Mark for the help.
                        I've met other difficulties while learning director. I've posted another problems. If you have time, I think I'm gonna need some more help again. Thank you!
