• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Seeing "File has been changed outside of RoboHelp... discard changes?"
New Here ,
Mar 10, 2015 Mar 10, 2015
I'm using: RoboHelp HTML, Version 10.0.1.292
I'm seeing the following message when I make changes within the RoboHelp project and then choose to close my project without saving the changes. It's not consistent behavior - it happens for some help files in the project but not all help files. If I save changes then it doesn't appear.
My steps:
1 - Open RoboHelp (I'm using RoboHelp 10) and make a simple text change to a help topic.
2 - Choose File > Close Project.
3 - Click No when the "Save changes to the following files?" confirmation appears.
This is when I see the message above. The message is confusing for several reasons: 1) I didn't edit the file outside the project, 2) I'm not sure what changes are being discarded if I click Yes, and 3) what's being loaded when I am closing the project.
Full disclosure - The only file I ever edit outside the project is the CSS and I am guilty of editing the CSS with the project open (to instantly see the results of my changes). Could this be the cause even though I haven't touched the CSS in well over a year? Is there old crud stuck in memory for certain help topics? I've never seen this message before and I've worked on this help project for many years.
Further testing - This message is popping up for a help topic added recently so I can't think it's related to any CSS changes made before the file was added. No other files have been edited outside the project that I can think of.
Message was edited by: Tricia Trujillo
Views
444
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Mar 11, 2015 Mar 11, 2015
Maybe with a copy of the project, try deleting the CPD file and then seeing if the offending topic still shows in Project Manager.
Go with Jeff's answer first though.
@petergrainge
Votes
Translate
Translate
Community Expert ,
@petergrainge
Votes
Translate
Translate
Report
Report
Community Expert ,
I had an answer for this one? You been reading my mind Peter? I was thinking – “Just ignore it if you hadn’t made any changes”
Votes
Translate
Translate
Report
Report
Community Expert ,
I must have been looking at another thread where you posted about shortening the path, which could also apply here.
Poster has made changes.
@petergrainge
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Just an FYI on this. I see this a fair amount. If memory serves, it can happen if you have one or more topics open in the editor, then you perform some action such as a find and replace across files or maybe selecting all the topics in the Topic list pod and assigning a different CSS. Basically, any action that RoboHelp might perform across a multitude of files.
That's why I often admonish class participants that it's generally a good idea to close all topics open in the editor before attempting these changes. As you seem to be acknowledging here, it's a very confusing message!
Cheers... Rick
Votes
Translate
Translate
Report
Report
New Here ,
Deleting the CPD file seems to have solved the problem. I'm not seeing this pesky message anymore. Thank you all for the comments!
- Tricia
Votes
Translate
Translate
Report
Report
New Here ,
I'm curious - I see the option "Clear project cache (.cpd file) before opening any project" in the General settings in RH. It's off by default but perhaps I should turn this on? Are there any concerns with having this enabled? Thanks again!
Votes
Translate
Translate
Report
Report
Community Expert ,
It can add a bit of time to the launch of a project if there are a lot of topics; other than that – no.
Votes
Translate
Translate
Report
Report
Community Expert ,
It has never given me a problem.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Cool, thanks again. I'll give it a shot.
- Tricia
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
