1 Reply Latest reply on Mar 16, 2015 10:11 AM by scottc30727408
    livecycle designer
    Ali Haider shiblu
      I have 3 fields, say A,B n C. if A= less than 10 then B n C will be 0. how can i make this coce.
      thanks
      Ali
        • 1. Re: livecycle designer
          scottc30727408 Level 1
          I am kind of an amateur. I have really only been using Livecycle for about a month and a half but this forum has been invaluable so I figured I should contribute back as best I can.
          Ok so your issue is that you want Fields B and C to show value 0 if Field a's value is less than 10.
          Using javascript use an if command.
          place a code similar to the one below on the exit event of field A.
          if Text.Field.A.rawValue  < 10;
          then
          Text.FIeld.B.rawValue == 0;
          endif
          please excuse any scripting mistakes. Normally, if I were writing a code like this, it would take several attempts to get everything just right.  As I said before, I am an amateur but I hope to get you on the right path.
