Expand my Community achievements bar.
Secure RTMP and Linux
Avatar
Level 1
Maybe someone can help me solve this mystery.
I have successfully used RTMP on Windows XP and RHEL 4 with
Flex 2.0.1 FDS and integrated JRun, Adobe FlashPlayer 9,0,28,0
The application works with a self-signed certificate using
HTTPS and RTMPS on Windows XP with the client app running in IE 7
and Firefox 1.5. The server certificates are signed with a trusted
root certificate, which in turn is in the certificate stores.
If I build the application on Linux with the same RTMPS
configuration as on Windows XP (except the difference in server
names), HTTPS on Linux works fine, but I have no joy with RTMPS.
<channel-definition id="my-rtmps"
class="mx.messaging.channels.SecureRTMPChannel">
<endpoint uri="rtmps://{server.name}:2099"
class="flex.messaging.endpoints.SecureRTMPEndpoint"/>
<properties>
<idle-timeout-minutes>20</idle-timeout-minutes>
<client-to-server-maxbps>100K</client-to-server-maxbps>
<server-to-client-maxbps>100K</server-to-client-maxbps>
<keystore-file>/opt/fds2/jrun4/lib/keystore</keystore-file>
<keystore-password>****</keystore-password>
</properties>
</channel-definition>
The following log example lists what happens with the first
FDS fill operation that the client performs.
There are NO error or warning entries in the client or server
logs - the logs end as indicated.
Client Log:
2/9/2007 11:52:42.312 [DEBUG] test.Tools challenge user
2/9/2007 11:53:08.843 [DEBUG] mx.data.DataService.sites
cds-producer-sites-null DataService.fill() called with 1 arguments.
(Array)#0
[0] "Duster"
<==== Trace ends here with Linux server =======
(the same trace on XP continues as follows)
2/9/2007 11:53:08.843 [WARN] mx.messaging.Consumer Client ID
specified in subscribe is ignored when a session is assigned.
2/9/2007 11:53:08.843 [INFO] mx.messaging.Consumer
'cds-consumer-sites-null' consumer subscribe.
2/9/2007 11:53:08.859 [INFO] mx.messaging.Channel 'my-rtmps'
channel endpoint set to rtmps://localhost:2099
channel settings are:
<channel id="my-rtmps"
type="mx.messaging.channels.SecureRTMPChannel">
<endpoint uri="rtmps://{server.name}:2099"/>
<properties/>
</channel>
2/9/2007 11:53:08.875 [INFO] mx.messaging.Producer
'cds-producer-sites-null' producer sending message
'9E153EC6-2413-5C93-72B5-A810F80BEB21'
Server log:
02/09 15:12:06 user FlexMxmlServlet: init
02/09 15:12:07 INFO Loading configuration file
/opt/fds2/jrun4/servers/default/acesis/WEB-INF/flex/flex-webtier-config.xml
/opt/fds2/jrun4/servers/default/acesis/WEB-INF/flex/flex-config.xml
02/09 15:12:07 INFO [cache] No existing dependency
information.
02/09 15:12:07 user FlexMxmlServlet: Starting Adobe Flex Web
Tier Compiler
02/09 15:12:07 user FlexMxmlServlet: Adobe Flex Web Tier
Compiler Build: 155539
02/09 15:12:07 user MessageBrokerServlet: init
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.834 [INFO]
[Configuration] Starting Adobe Flex Data Services 2 Express
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.838 [INFO]
[Configuration] Adobe Flex Data Services Build: 155539
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.914 [INFO]
[Configuration] Endpoint my-amf created with security: None
at URI:
http://{server.name}:{server.port}/{context.root}/messagebroker/amf
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.991 [INFO]
[Configuration] Endpoint my-rtmps created with security: None
at URI: rtmps://{server.name}:2099
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.994 [INFO]
[Configuration] Endpoint my-secure-polling-amf created with
security: None
at URI:
https://{server.name}:9100/{context.root}/messagebroker/amfsecurepolling
02/09 15:12:10 user [Flex] 02/09/2007 15:12:10.995 [INFO]
[Configuration] Endpoint my-polling-amf created with security: None
at URI:
http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.003 [INFO]
[Configuration] Endpoint my-http created with security: None
at URI:
http://{server.name}:{server.port}/{context.root}/messagebroker/http
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.009 [INFO]
[Configuration] Endpoint my-secure-amf created with security: None
at URI:
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.021 [INFO]
[Configuration] Endpoint my-rtmp created with security: None
at URI: rtmp://{server.name}:2038
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.023 [INFO]
[Configuration] Endpoint my-secure-http created with security: None
at URI:
https://{server.name}:9100/{context.root}/messagebroker/httpsecure
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.366 [INFO]
[Endpoint.RTMP] RTMPS-Server listening on port:2099
02/09 15:12:11 user [Flex] 02/09/2007 15:12:11.372 [INFO]
[Endpoint.RTMP] RTMP-Server listening on port:2038
02/09 15:12:11 user FlexSwfServlet: init
02/09 15:12:11 user FlexInternalServlet: init
02/09 15:13:08 user jrun.servlet.RedirectServlet: init
02/09 15:13:08 user FileServlet: init
02/09 15:13:27 user ServletInvoker: init
2007-02-09 15:14:48,391 INFO [RTMPS-Server]
security.SessionRegistry (SessionRegistry.java:340) - Created:
flex.messaging.endpoints.rtmp.RTMPFlexSession@1827002
(the previous entry is from a
FlexSessionListener#sessionCreated(FlexSession) implementation)
02/09 15:14:48 user [Flex] 02/09/2007 15:14:48.393 [DEBUG]
[Endpoint.RTMP] Created worker thread: RTMPS-Worker-0
02/09 15:14:48 user [Flex] 02/09/2007 15:14:48.396 [DEBUG]
[Endpoint.RTMP] Created worker thread: RTMPS-Worker-1
02/09 15:14:48 user [Flex] 02/09/2007 15:14:48.399 [DEBUG]
[Endpoint.RTMP] Created worker thread: RTMPS-Worker-2
02/09 15:14:48 user [Flex] 02/09/2007 15:14:48.488 [DEBUG]
[Endpoint.RTMP] Created worker thread: RTMPS-Worker-3
02/09 15:14:48 user [Flex] 02/09/2007 15:14:48.522 [DEBUG]
[Endpoint.RTMP] Created worker thread: RTMPS-Worker-4
<==== Trace ends here ====
The server log shows that the Flex session is created, RTMPS
worker threads are created, but then any messaging just stops.
There is no response to the fill operation as you can see in both
logs.
Firewalls are out of the picture - client and server are
connected via OpenVPN, Windows Firewall on the client is off. As
mentioned already, the exact same setup (with the same VPN) works
when using RTMP instead of RTMPS.
Just in case I've tried several different ports for RTMPS:
2099, 2039, 9105 and probably some others I don't recall anymore.
Any and all help would be appreciated - I'm out of ideas.
Jürgen Failenschmid
Avatar
Level 2
Jürgen,
We just spent a few days struggling with this very same
problem. It seems to only occur when using JDK1.5. RTMPS seems to
work well with JDK1.4 or 6 (Note I don't think 6 is supported
though)
Cheers,
-Vito
Avatar
Level 1
This was eventually tracked down together with Adobe's help
as a problem in the RTMPS-related implementation of LC DS and fixed
in a hotfix for LC DS 2.6
- Jürgen
