4 Replies Latest reply on Mar 13, 2015 4:43 PM by Wootie
    name layer same as group
    Wootie Level 1
      Is there a script made that will rename all selected layers the same name as the name of the group they are nested in.  (If not in a group then it skips them.)
        • 1. Re: name layer same as group
          c.pfaffenbichler Level 9
          I doubt such a Photoshop Script exists yet, but it seems feasible.
          Are you comfortable with AM code or do you prefer DOM? (Determining the selected Layers will probably need AM code anyway.)
          • 2. Re: name layer same as group
            Wootie Level 1
            To quote Willy Wonka:  "You are wrong, sir!  WRONG!!"  -ha.  Well, partially wrong...  Found a script someone has made that renames child layers the same as the parent, and adds a number after it, bonus. BUT if the parent group layer is also selected it does not work.  It would be much less of a headache for us if we could get around that.... anyone?
            (function () {
               try {var doc = activeDocument} catch(e) {return}
               var ls = getSelectedLayers();
               if (ls.length < 1) {return}
               k = 1;
               var parentName = "";
               for (i = 0; i<ls.length; i++) {
                  if (ls[i].parent.typename == "LayerSet"){
                     if (parentName != ls[i].parent.name) {k=1; parentName = ls[i].parent.name}
                     ls[i].name = ls[i].parent.name + k
                     k++
               function getSelectedLayers() {
                  var A = [];
                  var desc11 = new ActionDescriptor();
                  var ref9 = new ActionReference();
                  ref9.putClass(stringIDToTypeID('layerSection'));
                  desc11.putReference(charIDToTypeID('null'), ref9);
                  var ref10 = new ActionReference();
                  ref10.putEnumerated(charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt'));
                  desc11.putReference(charIDToTypeID('From'), ref10);
                  executeAction(charIDToTypeID('Mk  '), desc11, DialogModes.NO);
                  var gL = activeDocument.activeLayer.layers;
                  for (var i = 0; i < gL.length; i++) {
                     A.push(gL[i]);
                  executeAction(charIDToTypeID('undo'), undefined, DialogModes.NO);
                  return A;
            • 3. Re: name layer same as group
              Well, good thing I opined instead of denying …
              Looks like one of Paul’s.
              Does this work for you? (Based on code by Paul and Mike, I think.)
              // 2015, use it at your own risk;
              #target "photoshop-70.032"
              if (app.documents.length > 0) {
              app.activeDocument.suspendHistory("rename", "main ()");
              function main () {
              var myDocument = app.activeDocument;
              var theLayers = getSelectedLayersIdx();
              // do stuff;
              for (var n = 0; n < theLayers.length; n++) {
              selectLayerByIndex(theLayers[n], false);
              try {
              if (myDocument.activeLayer.typename != "LayerSet" && myDocument.activeLayer.parent != myDocument) {myDocument.activeLayer.name = myDocument.activeLayer.parent.name}
              catch (e) {}
              // reselect layers;
              for (var p = 0; p < theLayers.length; p++) {
                 selectLayerByIndex(theLayers[p], true)
              // by mike hale, via paul riggott;
              // http://forums.adobe.com/message/1944754#1944754
              function selectLayerByIndex(index,add){
              add = undefined ? add = false:add
              var ref = new ActionReference();
                  ref.putIndex(charIDToTypeID("Lyr "), index);
                  var desc = new ActionDescriptor();
                  desc.putReference(charIDToTypeID("null"), ref );
                     if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
                    desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                 try{
                  executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
              }catch(e){
              alert(e.message);
              ////// by paul mr;
              function getSelectedLayersIdx(){
                    var selectedLayers = new Array;
                    ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    var desc = executeActionGet(ref);
                    if( desc.hasKey( stringIDToTypeID( 'targetLayers' ) ) ){
                       desc = desc.getList( stringIDToTypeID( 'targetLayers' ));
                        var c = desc.count
                        var selectedLayers = new Array();
                        for(var i=0;i<c;i++){
                          try{
                             activeDocument.backgroundLayer;
                             selectedLayers.push(  desc.getReference( i ).getIndex() );
                          }catch(e){
                             selectedLayers.push(  desc.getReference( i ).getIndex()+1 );
                     }else{
                       ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                       ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                       try{
                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1);
                       }catch(e){
                          selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                    return selectedLayers;
              • 4. Re: name layer same as group
                Wootie Level 1
                Heck Yes!  Thanks c.pfaffenbichler, Paul and Mike.
