4 Replies Latest reply on Mar 13, 2015 1:38 PM by Chaz, W
    Channel Doesn't Exist or is not running
    Chaz, W Level 1
      I am using CF 11, IIS 7.5 and windows 7 pro. when I create a sample application using websockets I get the following results:
      {"msg":"ok","code":0,"clientid":40495741,"ns":"coldfusion.websocket.channels","reqType":"w elcome","type":"response"}
      {"msg":"Channel 'stocks' doesn't exist or is not running.","code":-1,"clientid":40495741,"ns":"coldfusion.websocket.channels","reqType":"s ubscribe","type":"response"}
      can someone help me understand why I am getting the second error message.
        • 1. Re: Channel Doesn't Exist or is not running
          haxtbh Level 4
          The channel is what the socket connection is trying to connect to. You usually define them in the Application.cfc. It looks something like this:
          this.wschannels = [{name="stock", cfclistener="stock"}];
          You are getting the error because the channel "stocks" is not listed here. Based on your previous forum post I imagine you have adapted a sample from somewhere but have not changed all the bits completely.
          • 2. Re: Channel Doesn't Exist or is not running
            Chaz, W Level 1
            thx haxtbh,
            I have this in my application.cfc
               this.wschannels=[{name="stocks"}];
            and this is in my index.cfm
            <script>
               //messagehandler recieves all the messages from websocket
               function mycbHandler( messageobj)
               var message = ColdFusion.JSON.encode(messageobj);
               var txt=document.getElementById("myDiv");
              txt.innerHTML +=message  +"<br>";
               //openhandler is invoked when socket connection is
               function openHandler()
              txt.innerHTML +="open Handler invoked <br>";
               function subscribeMe()
               var channelname = document.getElementById("channelname").value;
              mywsobj.subscribe(channelname);
               function getSubscribers()
               function unsubscribe_Me()
              mywsobj.unsubscribe(channelname);
               function publishClient()
               var message =  document.getElementById("msg").value;
              mywsobj.publish(channelname,message);
               function get_Subscriptions()
               function invokenpublish()
              cfcname = document.getElementById("cfcname").value;
              fnname = document.getElementById("fnname").value;
              mywsobj.invokeAndPublish(channelname, cfcname, fnname)
               function invokefn()
              mywsobj.invoke(cfcname, fnname)
               function opensocket()
              txt.innerHTML+="opening socket"+"<br >";
              x=mywsobj.openConnection();
               function stopsocket()
              txt.innerHTML+="closing socket"+"<br >";
              x=mywsobj.closeConnection();
               function checksocket()
               var x=mywsobj.isConnectionOpen();
              txt.innerHTML+=x+"<br >";
            </script>
            <form name="f">
            <cfwebsocket name="mywsobj" onMessage="mycbHandler" onOpen="openHandler"/>
            <br> Subscribe to:
            <input  id="channelname" name="channelname" type="text" value="stocks" >
            <input  id="stocksSubscribe" type="button" value="stocksSubscribe" onclick="subscribeMe();">
            <input  id="unsubscribeMe" type="button" value="unsubscribeMe" onclick="unsubscribe_Me();">
            <input  id="getSubscribersCF" type="button" value="getSubscribersCF" onclick="getSubscribers();">
            <input  id="getSubscriptions" type="button" value="getSubscriptions" onclick="get_Subscriptions();">
            <br>
            Message :<input id="msg" type="text" >
            <input  id="publishMe" type="button" value="publishMe" onclick="publishClient();">
            <br>
            CFC Name: <input  id="cfcname" name="cfcname" type="text" value="invokeandpublish" >
            Function Name: <input  id="fnname" name="fnname" type="text" value="publishall" >
            <input  id="invoke_publish" type="button" value="invoke_publish" onclick="invokenpublish();">
            <input  id="invoke" type="button" value="invoke" onclick="invokefn();">
            <br>
            <input  id="stop" name ="Close" type="button" value ="stop" onclick="stopsocket()" >
            <input  id="open" name ="Open" type="button" value ="open" onclick="opensocket()" >
            <input  id="check" name ="Check" type="button" value="check" onclick="checksocket()" >
            <br>
            <div id="myDiv"></div>
            yes this is something I copied for a sample that I am trying to get it to work so I can understand how this works.
            thanks for your help.
            if I am missing something please let me know.
            thanks,
            • 3. Re: Channel Doesn't Exist or is not running
              haxtbh Level 4
              When you run the page which button are you clicking first?
              Where did you get this sample from?
              • 4. Re: Channel Doesn't Exist or is not running
                Chaz, W Level 1
                I am clicking on the stocksSubscribe button:
                I got this sample from this site: Using WebSocket to broadcast messages - ColdFusion, English documentation - Adobe Learning Resources
                thanks,
