3 Replies Latest reply on Jun 12, 2015 9:12 AM by Ex_Posterboy
    Exporting Indesign book to PDF without canvas A. (background layer)
    Mewsical
      Hi everybody,
      I'm looking for a way to export my InDesign Book to a PDF file but without the Canvas-A. Only the top layer.
      Since in this book approx 136 files are attached and linked to other files, I'm looking for a simpeler way than just opening each and every file to alter this.
      In my background layer it displays my company logo, and we need to have the same file without this.
      Thanks in advance!
      Ivo
        • 1. Re: Exporting Indesign book to PDF without canvas A. (background layer)
          To turn off a layer you really want to mark it as non-printing in the file, ad that means the file needs to be opened and edited. It might be scriptable to speed it up, but my guess is that would take longer to write than it would to just open the files.
          • 2. Re: Exporting Indesign book to PDF without canvas A. (background layer)
            SJRiegel Adobe Community Professional & MVP
            Set the bottom layer to non-printing, then export the PDF.
            • 3. Re: Exporting Indesign book to PDF without canvas A. (background layer)
              Ex_Posterboy
              Are you saying you have 136 INDD files associated and synced within a single INDD book?
              I don't know of a way to turn off a layer across all the files in one shot, but here's a possible workaround:
              If you set up your files to use "Master Pages", then you could place those elements that need to be hidden/removed before pdf printing onto a layer within your master pages (in the file that is set to be the Style Source).
              Yes, you will still need to go thru each file one time to remove the elements from the numbered pages, but then you will never have to do anything like that again.
              I use "syncronized style-sourced Master Page elements" all the time to ensure I have consistent footers, slugs all the time, and I have also been tasked with making global revisions across multiple files, so this is my solution:
              1. remove/change the Master Page elements on the Style source file
              2. Re-sync all your files (master pages will be updated across the range of file).
              3. Export your PDFs from the Book palette menu.
              4. To make this even easier, I would suggest setting up a spare "Master Page set" (eg. called "B. with Logos") within the style source file so that it's quick to copy and paste the elements back onto the main Master Pages that are being used in your document files.
              Hope this might solve your issue.
              Cheers
