2 Replies Latest reply on Mar 12, 2015 9:53 AM by barryh46566004
    JSON into array and then CSS styling with data
    barryh46566004
      Hello,
      I'm desperate to solve this little problem creating a bar chart and I think my coding ability is letting me down. I have a simple .js file which contains a JSON object as follows:
      var bars = [
           {"type" : "data1",  "total" : 5},
           {"type" : "data2",  "total" : 10},
           {"type" : "data3",  "total" : 30}
      I have added this file to EA's scripts. I now want to pull all the "total" data into an array. Would the following work?
      var totals = new Array();
      for (i=0, i<3, i++) {
           totals[i] = bars[i].total;
      Once I have my array populated with the data I would like to use that data to set the heights of some elements. How do I put a variable into CSS code? For example:
      var elementHeight = 30;
      sym.$("element").css({"transform" : "scaleY(elementHeight)"});
      I can get this second line to work with just a number but I don't know how to pass a variable. Any help would be a lifesaver to a desperate man.
      Many thanks
      Barry
        • 1. Re: JSON into array and then CSS styling with data
          proberts-PJr0zI Level 2
          You're not referencing the variable in the example you posted, but rather defining the transform-scaleY as "elementHeight".
          sym.$("element").css({ "transform" : "scaleY(" + elementHeight + ")" });
          • 2. Re: JSON into array and then CSS styling with data
            barryh46566004 Level 1
            Thank you so much! I really appreciate that.
            That's one problem solved. I really struggle to find these little details sometimes.
            Now that I can use my variables in the css, any advice on how to populate my array?
            Here is the JSON in the js file I have attached to my EA session.
            var bars = [
            How do I access this data to transform the "scaleY" value for multiple elements through a for loop? My guess would be:
            for (var i=0, i<3, i++) {
                 sym.$("element" + i + " ").css({ "transform" : "scaleY(" + bars[i].total + ")" });
            Is this correct?
            Thanks again.
