3 Replies Latest reply on Mar 12, 2015 1:07 PM by try67
    Continuously get a value in order to autofill a text box.
    niah37410507
      I am creating a type of KPI scoreboard that will tell the user what type of level they are currently operating in depending how they respond to four questions.  I have set it up so that:
      Column 1 = Strongly Disagree = 0
      Column 2 = Disagree = 1
      Column 3 = Agree = 2
      Column 4 = Strongly Agree = 3
      I figured out how to calculate the sum of the check marks which shows up instantaneously.  My problem is that the Level Description associated with each sum does not continuously update like the sum does.
      When the sum is 0 "Not Started" shows:
      But when I change the box selection, the sum changes but the words don't:
      Not until I go back into Properties and re-run the JavaScript does it change:
      Here is my current code:
      // custom variable name for the level description
      // establish the name of the sum field
      var cSum = 'EESUM';
      // get the value of the sum field
      var nSum = this.getField(cSum).value;
      // set level description
      if(nSum == 0) event.value = "Not Started";
      else if((nSum > 0) && (nSum <= 4)) event.value = "Beginning";
      else if((nSum > 4) && (nSum <= 6)) event.value = "Learning";
      else if((nSum > 6) && (nSum <= 8)) event.value = "Performing";
      else if((nSum > 8) && (nSum <= 11)) event.value = "Achieving";
      else if(nSum == 12) event.value = "Excelling";
      // end of script
      Please help me find a way to continuously update the text box.  Is a while loop needed?
