3 Replies Latest reply on Mar 12, 2015 4:15 PM by cxvmcx
    Using javascript to save a pdf to a different directory and generating a new filename based on form fields in the document.
    cxvmcx Level 1
      I have built the following script in an attempt to create a submit button that will automatically save the document in a different directory on my computer. It will also use the form field data "customer" and "date" to generate the filename. I printed out the variable myPath and it looks like it printed the correct string. I keep getting the following error:
      TypeError: redeclaration of const path
      any help would be much appreciated.
      var customer = this.getField("Customer").value;
      var date = this.getField("Date").value;
      var path = "C:/Users/awilliams/My Documents/Test/"
        var reg = date.match(/(\d+)\/(\d+)\/(\d+)/);
      var myPath= "C:/Users/awilliams/My Documents/Test/" + customer + "_" + reg[1] + "." + reg[2] + "." +
      reg[3] + ".pdf";
      this.saveAs(myPath);
