This is odd -
I've created a conditional build-tag called FINANCE, and one
called EVERYTHING ELSE. So I've assigned FINANCE to just that Dept,
and all others get the EVERYTHING ELSE tag.
No when I compile it using the criteria, it does work
perfectly - with one exception. The resulting build gives me the
Finance Dept, but also one of the other depts - it's always the
same one....'Food and Beverage' which of course falls under the
'EVERYTHING ELSE' tag.
I cleared all the Conditional Build tags before doing the
above, and saved the project before going any further.
This only happens for the web based version, generating
*.DOC, *.PDF using the same tags does not exhibit this problem...
Now I'm confused......
Any ideas folks??
Al
