3 Replies Latest reply on Feb 16, 2007 10:17 AM by tedalde2
    Virtual Reality style project
    Aaron Hudson
      I'm currently trying to develop a project to be able to walk around a house and click on different items within the house. I've got a model from 3D Studio Max, imported it into Director and I'd now like to be able to walk around the house and click on different items, for example a couch, and make an event happen... hot spots I believe?
      Also, I need to be able to deploy such within Flash or a Visual Basic application.
      Any ideas or links to point me in the right direction?
      Thanks in advance!
        • 1. Re: Virtual Reality style project
          tedalde2 Level 2
          You won't be able to put Director into Flash (however you can put Flash into Director). For Visual Basic, this is the topic that can get you started: http://www.adobe.com/go/tn_12993
          Picking hotspots involves using the command modelsUnderLoc or modelsUnderRay. Something like this is needed in a script on the 3D sprite:
          If you're not into heavy coding, maybe some of the Library behaviors can help.
          • 2. Re: Virtual Reality style project
            Aaron Hudson Level 1
            Thanks for the response, I guess my next question is, if I've got a 3d model from 3ds Max, how do I go about being able to navigate around it (via Shockwave, in a website) and be able to click hotspots then... much like the Wonderville game?
            Thanks in advance!
            • 3. Re: Virtual Reality style project
              tedalde2 Level 2
              You'd export a W3D file from Max. You can select options that will affect how your scene will look and play; textures, etc. Then import the W3D into Director, and place the W3D on the stage/in the score. You can then apply behaviors to the sprite from the Library for camera movement actions and triggers. I've never used the Library extensively, but I think the behaviors work OK. You can also apply the script I posted above to get "picking" info for the W3D scene; if you click on a model named "yourCouch" then you can catch that and do something else. After you're done, you can export DCR and HTML files and your project will run in a browser using the Shockwave plugin.
              There's also a person who posts here sometimes who maintains this site:
              http://www.chromelib.com/
              Again, I've never used it but it looks like something you could use.
