0 Replies Latest reply on Mar 13, 2015 9:09 AM by brunog35080961
    Delay command within Indesign script
      I have a problem with "delay" command in a script.
      If I launch the script in AppleScrip Editor the delay is in effect but if I launch the script from Script Palett of InDesign the delay command is bypassed.
      There is an InDescign script command that suspend the execution of script as delay command
      This is the script
      tell application "Adobe InDesign CC 2014"
          if (count documents) is not equal to 0 then
                  set mySelection to selection
                  set myTextClasses to {word, text style range, line, paragraph, text column, text, story}
                  if (count mySelection) is not equal to 0 and class of item 1 of selection is in myTextClasses then
                      exit repeat
                          set Risposta to display dialog ("Select a text") buttons {"OK", "CANCEL"}
                          delay 5
                  end if
              end repeat
              display dialog ("No document opened.")
          end if
      end tell
