1 Reply Latest reply on Feb 14, 2007 2:22 PM by derobinson
    text after video
      I imported a video (progressive) and would like some text to appear after the video finishes. The video is in frame 1 and I inserted a keyframe after that and added text. When I play the movie all I see is the text blinking, no video. What did I do wrong?
      Thanks in advance.
        • 1. Re: text after video
          derobinson Level 1
          If you've placed the video in the timeline, then you need to give it enough frames to actually play (Flash should have prompted you to extend the timeline if you imported the vid straight to the stage). If you're using a playback component, you may need to stop themain timeline in frame one to give the video time to play, then attach a listener object to the playback component that will seend the playhead to frame 2 when the video has finished playing.
          Hope that helps!
