1 Reply Latest reply on Mar 14, 2015 2:10 PM by A.T. Romano
    Project cannot be opened in Premiere Elements 11.  "SCWeb.sc file is missing"
    RB115
      Adobe Premiere Elements 11 cannot open new or existing project. Error is "SCWeb.sc file is missing". Please help.
        • 1. Re: Project cannot be opened in Premiere Elements 11.  "SCWeb.sc file is missing"
          A.T. Romano Level 7
          rb115
          On what computer operating system is your Premiere Elements 11 running?
          When did Premiere Elements 11 last not have this missing SCWeb.sc file missing issue? Did you install any
          new program around the time the SCWeb.sc matter set in?
          For now...assuming Windows 7, 8, or 8.1 64 bit...
          Does an antivirus scan detect any security problems? If not, then
          determine that the problem exists with or without the antivirus and firewall(s) disabled.
          If it does, then
          1. Delete the Adobe Premiere Elements Prefs file and, if necessary, the whole 11.0 Folder in which the Adobe
          Premiere Elements Prefs file exists.
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Adobe
          11.0
          and, in the 11.0 Folder, is the Adobe Premiere Elements Prefs file that you delete. If that does not work, then delete the
          whole 11.0 Folder in which the Adobe Premiere Elements Prefs file exists. Make sure to be working with Folder Option
          Show Hidden Files, Folders, and Drives enabled so that you can see the complete path cited.
          2. Uninstall, do free ccleaner run through (regular and registry cleaner parts), and then install with
          CCleaner - PC Optimization and Cleaning - Free Download
          We will be watching for your progress as your time permits.
          Thank you.
          ATR
