6 Replies Latest reply on Feb 16, 2007 3:52 AM by odie11
    Only first Attached MovieClip instance 'responds' to keyPress
    odie11
      I am attaching several instances of a nested MC which has some on
      keyPress code. Only the very first instance responds to the keyPress
      events. Why don't the other instances behave the same? The only
      logical reason I can think of is the subsequent instances are at
      different depths, could this be the reason? How can I get all
      instances to respond to the keyPress event?
        • 1. Re: Only first Attached MovieClip instance 'responds' to keyPress
          Pop_Clingwrap
          What is the code that is failing and how are you attaching the button?
          Put the code up here and I'll have a look. Cant promise I will solve it though :)
          • 2. Re: Only first Attached MovieClip instance 'responds' to keyPress
            odie11 Level 1
            Here is the code which is placed on a movieclip nested inside the movieclip I use for the attachMovieclip instances. Again the first instance works fine but the subesequent instances do not execute this code.
            • 3. Re: Only first Attached MovieClip instance 'responds' to keyPress
              Pop_Clingwrap Level 1
              I have had a play around and it is not working at all for me.
              What exactly are you wanting to happen to each instance when the keys are pressed, should they move individually or all together as one?
              If you can describe the finished thing I can probably get it working.
              • 4. Re: Only first Attached MovieClip instance 'responds' to keyPress
                odie11 Level 1
                Thnaks for helping me out Pop.
                I'm trying to make a time grid display consisting of vertical lines which can be panned and zoomed. To accomplish this I'm attaching individual vertical lines, each as an individual movieclip. The code I posted has to be attached to an object instance so I nested an instance of a vertical line MC inside another to make a parent movieclip which I can attach or remove at runtime.
                I'm probably going about this wrong, so I'd be happy with any approach which achieves the end result... - a zoomable/scrollable time grid display.
                • 5. Re: Only first Attached MovieClip instance 'responds' to keyPress
                  Level 7
                  odie11,
                  Actually, you don't have to attach that code directly to the object (in
                  fact, that's been "bad form" since Flash MX, though on() and onClipEvent()
                  still work fine). I tried to duplicate your issue and was able to ... and
                  frankly, I can't imagine why each separate instance wouldn't follow through.
                  First, I thought it might be an issue of focus, but I switched focus back
                  and forth among the movie clips (by tabbing) and that didn't seem to fix the
                  problem. It might actually *be* a focus issue, but additional testing would
                  take more time, and today is a bit tight for me.
                  Check out your other options, for sure. Since Flash MX, it's been
                  possible to assign event handlers from keyframe scripts. That way, you can
                  attach your movie clips (nested or not) and refer to them by the unique
                  instance name you give each one as you attach.
                  http://www.quip.net/blog/2006/flash/museum-pieces-on-and-onclipevent
                  David Stiller
                  Adobe Community Expert
                  Dev blog, http://www.quip.net/blog/
                  "Luck is the residue of good design."
                  • 6. Re: Only first Attached MovieClip instance 'responds' to keyPress
                    odie11 Level 1
                    Thanks all. I am now using an event handler from a keyframe script and have made some good progress (panning works... although zooming is proving much harder...;)
                    David, I found your comments (and related bloggings) very useful, much of it under the category "wish I had have known that earlier". I agree, for the most part, it makes more sense to code event handlers from a keyframe rather than attached to individual object instances.
                    Initially I guess I was trying to use a more object oriented coding approach where the event handling was a 'method' of the object. My real problem is I couldn't (and still can't) understand how to attach the event handling code to the symbol itself (object class?) and not a specific instance. You know for example a "ball" symbol might have a bounce method - it seems somewhat natural (OOP perhaps?) to want to attach the event handling for 'bounce' to the "ball" symbol or class.
                    I am also currently thinking actionscript has evolved at an extreme level over the past several years resulting in many many pieces of deprecated, or at least less than efficient code snippets, tutorials, postings, samples, etc.
