2 Replies Latest reply on Mar 16, 2015 5:17 AM by Clark2015
    Initialize multiple popups
    Clark2015
      I am trying to put two popups in a custom dialog. I am having trouble though because I can't figure out how to initialize the two different arrays that hold the choices for the two popups. When I use this code it, the first popup shows sub1 for the choices but popup2 doesn't show any choices. Any direction on how to fix this would be very helpful!
           initialize: function(dialog)
                dialog.load(
                "sub1":
                     "example1": -1,
                     "example2": -2,
                     "example3": -3,
                     "example4": -4
                "sub2":
                     "example5": -1,
                     "example6": -2,
                     "example7": -3,
                     "example8": -4
      //In the description where I create the popups
                               type: "cluster",
                               elements:
                                         type: "static_text",
                                         name: "Make a choice",
                                         font: "default"
                                         type: "popup",
                                         item_id: "sub1",
                                         width: 200
                               type: "cluster",
                               elements:
                                         font: "default"
                                         type: "popup",
                                         item_id: "sub2",
                                         width: 200
        • 1. Re: Initialize multiple popups
          George_Johnson MVP & Adobe Community Professional
          Try this:
                    dialog.load(
                    "sub1":
                         "example1": -1,
                         "example2": -2,
                         "example3": -3,
                         "example4": -4
                    "sub2":
                         "example5": -1,
                         "example6": -2,
                         "example7": -3,
                         "example8": -4
          • 2. Re: Initialize multiple popups
            Clark2015 Level 1
            That worked, thanks for the help!
