• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
error on all hidden type for tag cfinpit . help!
New Here ,
Feb 08, 2007 Feb 08, 2007
I've a problem with some coldfusion 6.1 scripts running on a server with coldfusion 7.
It seems that it isn't accepting the hidden type for the tag cfinput, as it throws an error
described on the following lines:
The value of the attribute TYPE, which is currently "Hidden", must be
one of the values: RADIO,CHECKBOX,PASSWORD,TEXT.
The error occurred in
D:\hshome\user102\midasadmin.com\admin\pharmacies_edit.cfm: line 251
249 :
250 : <cfform>
251 : <cfinput type="Hidden" name="shipments" value="TRUE">
This code was working good on a coldfusion mx 6.1 server, but it wont work in the new server. When reffering to the knowledge base this code appears to be right and should run OK on a server with CF 7.
Is there anything wrong on that line?
or what could be the problem here?
please if you can reply to my email as well.
THANKS! 🙂
TOPICS
Advanced techniques
Views
333
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Which precise version of CFMX7? Your code works fine for me on
7,0,2,142559.
With such simple requirements for the tag: why are you even bothering using
<cfinput> rather that just a simple <input> tag? You're not using any of
the functionality that <cfinput> adds to the mix.
Adam
Votes
Translate
Translate
Report
Report
New Here ,
Feb 09, 2007 Feb 09, 2007
i might be the server then...
do u know any cheap good cf server?
i run an ecommerce application with multiple fronts (like 1 backend with more than 3 websites)
Votes
Translate
Translate
Report
Report
LEGEND ,
You did not answer my question as to why you want to use <cfinput> in this
situation anyhow?
Adam
Votes
Translate
Translate
Report
Report
LEGEND ,
using <cfinput> rather that just a simple <input> tag? You're not
using any of the functionality that <cfinput> adds to the mix.
Does <cfinput...> support the hidden input type? What benefit would a
<cfinput> bring to a hidden field? I would think you would want to use
basic <input...> tags for these fields.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2007 Feb 10, 2007
this is a very complex application. I'm not including all the code here. This application was built by somebody else and was 100% functional as i was one of its users.
we are trying to make it live again.
the cfinput is just a single tiny detail, i dunno why they'd use a cf tag but we cannot fix more than 500 files right now.
we have to stick to what already was working. I was just wondering why would this cause an error
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
> this cause an error
Well you could do one of these:
1) reinstall CF, as it looks like your current one is bung.
2) simply change the - completely redundant and incorrect - <cfinput> with
an equivalent <input>.
Those, by the sounds of it, are your options.
It's up to you.
I know what *I'd* be doing, though.
Adam
Votes
Translate
Translate
Report
Report
Resources
Documentation
