2 Replies Latest reply on Jan 10, 2017 4:51 PM by Steve Werner
    Stop SOAP initiated running task
    diggeralmu Level 1
      Is there a way to stop a task initiated via SOAP (using java for the SOAP client and javascript for the Indesign server scripting) from running?
      One of the scenarios is when the calling program is terminated (either manually or unexpectedly) or when the network experiences some problems and the connection is disconnected, I would like to stop the task from continuing.
      We are generating intensive processing (e.g generating documents and merging multiple documents) and generation may take some time especially when dealing with large tables( tables with 1000 rows) with is using a bit of the processing and memory. I would like a way to stop/terminate the task itself (and not  need to restart/stop indesign server to avoid quitting other tasks)
      I have tried to establish a same session using the same session id so I can somehow mark a variable that will stop execution at certain points but indesign server throws an error back to the soap client that the session has already been established.
      Please advise if there is a way for stopping a task in indesign server or a way to make 2 different SOAP calls have the same session? (do I need to use the same service object / stub object?) Tried both but it seems I may be missing some step.
      Btw, using Windows Server 2012 and Indesign Server cs6
