2 Replies Latest reply on Mar 16, 2015 11:53 PM by Nems77
    vbscript crop() with photoshop
    Nems77
      Hi Guys,
      can someone helps me about method crop() with vbscript.
      I never get it work..
      Set app = CreateObject("Photoshop.Application")
           set idoc = app.ActiveDocument
      idoc.Crop( Array(25,0,125,100),0,100,100,72)
      Than you for help.
      nems.
        • 1. Re: vbscript crop() with photoshop
          Philip Cord Level 4
          On many versions of Photoshop there is a folder that has examples, this is in the application - scripting - sample scripts.
          This is the example for crop using vbs.
          ' Copyright 2002-2008.  Adobe Systems, Incorporated.  All rights reserved.
          ' This script will iterate through all of the layers of a document. If the
          ' layer is not a text layer, the layer's color values are inverted. If it
          ' is the background layer, also rotate, then crop the entire canvas. In
          ' order to invert the entire document, each layer must be inverted
          ' independently (or flattened beforehand).
          ' Before running this script, create a document with a few non-text layers.
          Option Explicit
          Dim appRef
          Set appRef = CreateObject( "Photoshop.Application" )
          appRef.BringToFront
          Dim docRef
          Dim cropBounds
          Dim artLayerRef
          Dim strtRulerUnits
          If ( appRef.Documents.Count > 0 ) Then
              strtRulerUnits = appRef.Preferences.RulerUnits
              appRef.Preferences.RulerUnits = 1 ' psPixels
              Set docRef = appRef.ActiveDocument
              Dim offset
              offset = 20
              cropBounds = Array( 20, 20, docRef.Width - offset, docRef.Height - offset )
              ' Check each ArtLayer to see what type it is.  Ignore all text layers.
              For Each artLayerRef In docRef.ArtLayers
                  ' For every non-text layer, invert the contents.
                  If ( Not artLayerRef.Kind = 2 ) Then ' psTextLayer
                      ' Need to make the active layer this non-text layer in order to modify the layer.
                      ' I want to invert the contents of the entire doc (excluding text), so need to
                      ' invert every layer.
                      docRef.ActiveLayer = artLayerRef
                      ' See if there is anything on this layer, you can't invert an empty layer
                      Dim w, h
                      w = artLayerRef.Bounds(0)(2) - artLayerRef.Bounds(0)(0)
                      h = artLayerRef.Bounds(0)(3) - artLayerRef.Bounds(0)(1)
                      If w Or h Then
                          docRef.ActiveLayer.Invert
                      End If
                      ' The background layer is always non-text, so test to see if it's the background layer.
                      ' If it is, then rotate and crop it.
                      If ( artLayerRef.IsBackgroundLayer ) Then
                          docRef.RotateCanvas 45
                          docRef.Crop cropBounds
                      End If
                  End If
              Next
              appRef.Preferences.RulerUnits = strtRulerUnits
          Else
              MsgBox "Create a document with a few layers before running this script"
          End If
          MsgBox "Crop complete"
          • 2. Re: vbscript crop() with photoshop
            Nems77 Level 1
            Thank you Philip for your answer. I didn't get this exemple in my folder.. strange..
