23 Replies Latest reply on Mar 23, 2015 12:07 AM by c.pfaffenbichler
    Batch Replace Smart Object With Different Image Quality and Sizes
    frogeyed
      Hi there,
      I need help. I have this template that is in 1000x1000pixel and 300 dpi. I'm trying to replace the smart object inside with various JPEG that I have. These JPEG comes in large image sizes but lower than 300dpi. The issues is, when I run the script that I have, some of the pictures become really pixelated. Beforehand, I resized them to fit into the empty place in sizes that I find fit the best (8 cm x 6 cm). Some of them work okey, but then some of them just pretty bad. I'm wondering if you can help me fix the script that I have so I didn't have to resized the images before running the script, and how to make all the image fit automatically to the initial size of the image that I put the first there.
      below is the script that I am using and the screenshot of my template:
      #target photoshop
      if (app.documents.length > 0) {
      var myDocument = app.activeDocument;
      var theName= myDocument.name.match(/(.*)\.[^\.]+$/)[1];
      var thePath = myDocument.path;
      var theLayer = myDocument.activeLayer;
      // psd options;
      psdOpts = new PhotoshopSaveOptions();
      psdOpts.embedColorProfile = true;
      psdOpts.alphaChannels = true;
      psdOpts.layers = true;
      psdOpts.spotColors = true;
      // check if layer is smart object;
      if (theLayer.kind != "LayerKind.SMARTOBJECT") {alert ("selected layer is not a smart object")}
      else {
      // select files;
      if ($.os.search(/windows/i) != -1) {var theFiles = File.openDialog ("please select files", "*.psd;*.jpg;*.jpeg;*.tif", true)}
      else {var theFiles = File.openDialog ("please select files", getFiles, true)};
      if (theFiles) {
      // work through the array;
      for (var m = 0; m < theFiles.length; m++) {
      // replace smart object;
      theLayer = replaceContents (theFiles[m], theLayer);
      var theNewName = theFiles[m].name.match(/(.*)\.[^\.]+$/)[1];
      //Raise color picker for Back cover;
      try {
      app.activeDocument.activeLayer = app.activeDocument.layers[app.activeDocument.layers.length - 1];
      var idsetd = charIDToTypeID( "setd" );
      var desc7 = new ActionDescriptor();
      var idnull = charIDToTypeID( "null" );
      var ref2 = new ActionReference();
      var idcontentLayer = stringIDToTypeID( "contentLayer" );
      var idOrdn = charIDToTypeID( "Ordn" );
      var idTrgt = charIDToTypeID( "Trgt" );
      ref2.putEnumerated( idcontentLayer, idOrdn, idTrgt );
      desc7.putReference( idnull, ref2 );
      var idT = charIDToTypeID( "T " );
      var desc8 = new ActionDescriptor();
      var idClr = charIDToTypeID( "Clr " );
      var idsolidColorLayer = stringIDToTypeID( "solidColorLayer" );
      desc7.putObject( idT, idsolidColorLayer, desc8 );
      executeAction( idsetd, desc7, DialogModes.ALL );
      } catch (e) {};
      //save jpg;
      myDocument.saveAs((new File(thePath+"/"+theName+"_"+theNewName+".jpg")),psdOpts,true);
      ////// get psds, tifs and jpgs from files //////
      function getFiles (theFile) {
      if (theFile.name.match(/\.(psd|tif|jpeg|jpg)$/i) != null || theFile.constructor.name == "Folder") {
      return true
      ////// replace contents //////
      function replaceContents (newFile, theSO) {
      app.activeDocument.activeLayer = theSO;
      var idplacedLayerReplaceContents = stringIDToTypeID( "placedLayerReplaceContents" );
      var desc3 = new ActionDescriptor();
      desc3.putPath( idnull, new File( newFile ) );
      var idPgNm = charIDToTypeID( "PgNm" );
      desc3.putInteger( idPgNm, 1 );
      executeAction( idplacedLayerReplaceContents, desc3, DialogModes.NO );
      return app.activeDocument.activeLayer
        • 1. Re: Batch Replace Smart Object With Different Image Quality and Sizes
          c.pfaffenbichler Level 9
          Do the replacement images all have the same proportions as the Smart Object?
          If not how are they to be placed – according to the original SO’s width or height?
          • 2. Re: Batch Replace Smart Object With Different Image Quality and Sizes
            frogeyed Level 1
            The replacement images have the same proportions, I only run portraits images to replace portraits, they are just in different size and pixels. I wish to place it according to the original SO's width and height.
            • 3. Re: Batch Replace Smart Object With Different Image Quality and Sizes
              This would scale the placed SO according to the original SO’s width.
              If they all indeed have the same proportions that should suffice.
              // 2015, use it at your own risk;
              #target "photoshop-70.032"
              // psd options;
              else {
              // select files;
              if (theFiles) {
              // set to pixels;
              var originalRulerUnits = app.preferences.rulerUnits;
              app.preferences.rulerUnits = Units.PIXELS;
              // get bounds;
              var theBounds = theLayer.bounds;
              // scale;
              var newBounds = theLayer.bounds;
              var theFactor = (Number(theBounds[2])-Number(theBounds[0]))/(Number(newBounds[2])-Number(newBounds[0]))*1 00;
              theLayer.resize(theFactor, theFactor, AnchorPosition.MIDDLECENTER);
              //save psd;
              myDocument.saveAs((new File(thePath+"/"+theName+"_"+theNewName+".psd")),psdOpts,true);
              // reset;
              return true
              • 4. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                frogeyed Level 1
                Thanks!
                I got into an error with this script. Screenshot attached below:
                • 5. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                  Philip Cord Level 4
                  There is a space between the last number that should not be there *1 00; should be *100;
                  • 6. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                    frogeyed Level 1
                    This is perfect! Thank you for all of you for the help. Really appreciate it
                    • 7. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                      frogeyed Level 1
                      Sorry, this came up after I successfully scripted 5 images.
                      How can I fix this?
                      • 8. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                        What is theFactor in this case?
                        Could you please post a screenshot with the Layers Panel visible?
                        • 9. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                          What alert do you get when you insert the line
                          alert ("old bounds\n"+theBounds.join("\n")+"\n\nnew bounds\n"+newBounds.join("\n"));
                          before
                          • 10. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                            I do what you want to do all the time, However I may not always do  it by replacing the smart layer contents.  I may replace the layer or change the smart object layer transform after replacing the contents..   Replacing a smart object content is a red herring when different sizes and aspect ratios are involved.  It does not work without additional work.   You need  the replacement to be sized positioned and masked  to where it should be,    My templates have alpha channels that map image location shape and size.  The Alpha channel are named  "Image 1", "Image 2" .... Image n and image are populated in order layered just above the background layer,  Populated composite retain these  Alpha channels so they can be used to replace image layers.  I only have one script to replace that will current layer populated image.  However all populating script can place any size image to location.
                            Not good looking lots of script listener code here.  It was also coded back is CS2 timeframe where selection bounds did not work so I needed to hammer out a selections bounds. I was also just starting to hack at scripting. There were bugs added in various version of Photoshop where I needed to add patches to keep the scripts working.  This script will also fail in perpetual CS6 if the users default interpolation method is Adobe default "Bicubic Automatic" for Adobe failed to add support into CS6 scripting.  I filed a bug report. Adobe fixed the Bug in the subscription CS6 version 13.1.2  but not in the perpetual verion 13.0.1.3.  I do not know if it is fixed in the Mac version 13.0.6.
                            // 2010  John J. McAssey (JJMack)
                            // This script is supplied as is. It is provided as freeware.
                            // The author accepts no liability for any problems arising from its use.
                            // Image files and Template Alpha Channel "Image 1" should have the same orientation matching Aspect
                            // ratio is even better.  This script will try to transform the placed Images to match the Image 1 Alpha channel as
                            // best as it can and even try to handle orientation miss matches.
                            /* Help Category note tag menu can be used to place script in automate menu
                            <javascriptresource>
                            <about>$$$/JavaScripts/ReplaceCollageImage/About=JJMack's Replace Collage Image.^r^rCopyright 2010 Mouseprints.^r^rReplace Collage Populated Image</about>
                            <category>JJMack's Collage Script</category>
                            </javascriptresource>
                            // enable double-clicking from Mac Finder or Windows Explorer
                            #target photoshop // this command only works in Photoshop CS2 and higher
                            // bring application forward for double-click events
                            app.bringToFront();
                            //       SET-UP
                            cTID = function(s) { return app.charIDToTypeID(s); };
                            sTID = function(s) { return app.stringIDToTypeID(s); };
                            var gVersion = 1.0;
                            // a global variable for the title of the dialog
                            // this string will also be used for the preferences file I write to disk
                            // Photoshop Install Directory/Presets/Image Processor/Image Processor.xml for example
                            var gScriptName = "ReplaceCollageImage";
                            // remember the dialog modes
                            var saveDialogMode = app.displayDialogs;
                            app.displayDialogs = DialogModes.NO;
                            try {
                              // make sure they are running Photoshop CS2
                              CheckVersion();
                            // Lot's of things can go wrong, Give a generic alert and see if they want the details
                            catch(e) {
                              if ( confirm("Sorry, something major happened and I can't continue! Would you like to see more info?" ) ) {
                              alert(e);
                            // Save the current preferences
                            var startRulerUnits = app.preferences.rulerUnits;
                            var startTypeUnits = app.preferences.typeUnits;
                            var startDisplayDialogs = app.displayDialogs;
                            // Set Photoshop to use pixels and display no dialogs
                            app.preferences.typeUnits = TypeUnits.PIXELS;
                            // Set the script location
                            var scriptLocation = findScript() + "0";
                            //=====================Start=====================================================
                            var doc = activeDocument;
                            var saveactivelayer = activeDocument.activeLayer
                            var layers = activeDocument.layers;
                            activeDocument.activeLayer = layers[layers.length-1]; // Target Bottom Layer
                            if ( !activeDocument.activeLayer.isBackgroundLayer ) {
                              alert("Document does not have the Required Photoshop Background Layer");
                            else { // Has Background
                              var abort = false;
                              // ======Load Image 1 Selection===============================
                                 var desc2 = new ActionDescriptor();
                                     var ref1 = new ActionReference();
                                    var idChnl = charIDToTypeID( "Chnl" );
                                     var idfsel = charIDToTypeID( "fsel" );
                                     ref1.putProperty( idChnl, idfsel );
                                 desc2.putReference( idnull, ref1 );
                                     ref2.putName( idChnl, "Image 1" );
                                 desc2.putReference( idT, ref2 );
                              try{
                              executeAction( idsetd, desc2, DialogModes.NO );
                              }catch(e){
                              alert("Document does not have the Required Image 1 Alpha Channel");
                              var abort = true
                              var imageNumber = 1;
                              var numberOfImages = getAlphaImageChannels()
                              //alert("numberOfImages = " + numberOfImages + " Number of Layers = " + layers.length + " saveactivelayer = " + saveactivelayer  );
                              for (var i = layers.length-1; i>=0; i--) { if (layers[i]==saveactivelayer) layernumber = i;};
                                    imageNumber = (layers.length-1)-layernumber;
                              activeDocument.activeLayer = saveactivelayer;
                              //alert ("layernumber = " + layernumber + " imageNumber = " + imageNumber);
                              if ( imageNumber >= 1 && imageNumber <= numberOfImages && activeDocument.activeLayer.kind  == LayerKind.SMARTOBJECT) { //active layer is within the range of image 1 through Image n
                              file = File.openDialog("Select Image" , "Select:*.nef;*.cr2;*.crw;*.dcs;*.raf;*.arw;*.orf;*.dng;*.psd;*.tif;*.tiff;*.jpg;*.jpe;*. jpeg;*.png;*.bmp");
                              if ( file != null ) { // image selected
                              //alert("file = " + file);
                              deletelayermask()
                              replaceImage(file)
                              // resize smart object layer to just cover canvas area aspect ratio and size
                              // Get Smart Object current width and height
                              var LB = activeDocument.activeLayer.bounds;
                              var LWidth = (LB[2].value) - (LB[0].value);
                              var LHeight = (LB[3].value) - (LB[1].value);
                              // Get Alpha Channel's width and height Selection Bounds did not work???
                              makeLayer(); // Make Temp Work Layer
                              loadAlpha("Image " + imageNumber ); // Load Image Alpha Channel
                              fillBlack();
                              activeDocument.selection.invert(); // Inverse
                              // If image size equals canvas size no pixels neill be selected clear will fail
                              try{
                              activeDocument.selection.clear(); // One clear did not work
                              activeDocument.selection.clear(); // Two did the trick
                              }catch(e){}
                              activeDocument.selection.deselect(); // Deselect
                              var SB = activeDocument.activeLayer.bounds; // Get the bounds of the work layer
                              var SWidth = (SB[2].value) - (SB[0].value); // Area width
                              var SHeight = (SB[3].value) - (SB[1].value); // Area height
                              activeDocument.activeLayer.remove(); // Remove Work layer
                              var userResampleMethod = app.preferences.interpolation; // Save interpolation settings
                              app.preferences.interpolation = ResampleMethod.BICUBIC; // resample interpolation bicubic
                              if (LWidth/LHeight<SWidth/SHeight) { // Smart Object layer Aspect Ratio less the Canvas area Aspect Ratio
                              var percentageChange = ((SWidth/LWidth)*100);  // Resize to canvas area width
                              activeDocument.activeLayer.resize(percentageChange,percentageChange,AnchorPosition.MIDDLE CENTER);
                              else {
                              var percentageChange = ((SHeight/LHeight)*100); // resize to canvas area height
                              app.preferences.interpolation = userResampleMethod; // Reset interpolation setting
                              // Load Alpha Channel as a selection and align image to it
                              loadAlpha("Image " + imageNumber);
                              //align('AdTp');
                              //align('AdLf');
                              align('AdCV');
                              align('AdCH');
                              // Add Layer mask using Alpha channel Image1
                              // linkedlayerMask(); // Add inked Layer Mask
                              layerMask(); // Add Layer Mask
                              targetRGB()
                              // Isolate Image name
                              var Name =  decodeURI(file).replace(/\.[^\.]+$/, ''); // strip the extension off
                              var imagePath = "";
                              while (Name.indexOf("/") != -1 ) { // Strip Path
                              imagePath= imagePath + Name.substr(0, Name.indexOf("/") + 1);
                              Name = Name.substr(Name.indexOf("/") + 1 ,);
                              if (Name.indexOf("#") != -1 ) { // Strip any prefix sequence number off
                              prefix = Name.substr(0,Name.indexOf("#") );
                              Name = Name.substr(Name.indexOf("#") + 1 ,);
                              app.activeDocument.activeLayer.name = Name
                              } // end not null
                              } //end is an image layer
                              else { alert("Target a Smart Object Image layer to replace/"); }
                            } //end has Background
                            // Return the app preferences
                            app.preferences.rulerUnits = startRulerUnits;
                            app.preferences.typeUnits = startTypeUnits;
                            app.displayDialogs = saveDialogMode;
                            // The end //
                            // Helper Functions //
                            function placeImage(file) {
                              // =======avoid bug in cs2 and maybe CS4 ==================================
                              var idslct = charIDToTypeID( "slct" );
                                 var desc5 = new ActionDescriptor();
                                     var ref3 = new ActionReference();
                                     var idRGB = charIDToTypeID( "RGB " );
                                     ref3.putEnumerated( idChnl, idChnl, idRGB );
                                 desc5.putReference( idnull, ref3 );
                                 var idMkVs = charIDToTypeID( "MkVs" );
                                 desc5.putBoolean( idMkVs, false );
                              executeAction( idslct, desc5, DialogModes.NO );
                              // Place in the file
                              var idPlc = charIDToTypeID( "Plc " );
                                 desc5.putPath( idnull, new File( file ) );
                                 var idFTcs = charIDToTypeID( "FTcs" );
                                 var idQCSt = charIDToTypeID( "QCSt" );
                                 var idQcsa = charIDToTypeID( "Qcsa" );
                                 desc5.putEnumerated( idFTcs, idQCSt, idQcsa );
                                 var idOfst = charIDToTypeID( "Ofst" );
                                     var desc6 = new ActionDescriptor();
                                     var idHrzn = charIDToTypeID( "Hrzn" );
                                     var idPxl = charIDToTypeID( "#Pxl" );
                                     desc6.putUnitDouble( idHrzn, idPxl, 0.000000 );
                                     var idVrtc = charIDToTypeID( "Vrtc" );
                                     desc6.putUnitDouble( idVrtc, idPxl, 0.000000 );
                                 desc5.putObject( idOfst, idOfst, desc6 );
                              executeAction( idPlc, desc5, DialogModes.NO );
                              // because can't get the scale of a smart object, reset to 100%
                              activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER);
                              return app.activeDocument.activeLayer;
                            function targetRGB() {
                            function replaceImage(file) {
                              // ===============Replace Contents========================================
                                 var desc18 = new ActionDescriptor();
                                 desc18.putPath( idnull, new File( file ) );
                              executeAction( idplacedLayerReplaceContents, desc18, DialogModes.NO );
                            function deletelayermask() {
                              var idDlt = charIDToTypeID( "Dlt " );
                                 var desc17 = new ActionDescriptor();
                                     var ref17 = new ActionReference();
                                     var idMsk = charIDToTypeID( "Msk " );
                                     ref17.putEnumerated( idChnl, idChnl, idMsk );
                                 desc17.putReference( idnull, ref17 );
                              try{
                              executeAction( idDlt, desc17, DialogModes.NO );
                              }catch(e){}
                            function makeLayer(){
                              var idMk = charIDToTypeID( "Mk  " );
                                 var desc4 = new ActionDescriptor();
                                     var idLyr = charIDToTypeID( "Lyr " );
                                     ref3.putClass( idLyr );
                                 desc4.putReference( idnull, ref3 );
                              executeAction( idMk, desc4, DialogModes.NO );
                            function layerBackward(){
                                 var desc9 = new ActionDescriptor();
                                    var ref6 = new ActionReference();
                                     var idBckw = charIDToTypeID( "Bckw" );
                                    ref6.putEnumerated( idLyr, idOrdn, idBckw );
                                 desc9.putReference( idnull, ref6 );
                                 desc9.putBoolean( idMkVs, false );
                              executeAction( idslct, desc9, DialogModes.NO );
                            function layerForward(){
                                 var desc26 = new ActionDescriptor();
                                     var ref19 = new ActionReference();
                                     var idFrwr = charIDToTypeID( "Frwr" );
                                     ref19.putEnumerated( idLyr, idOrdn, idFrwr );
                                desc26.putReference( idnull, ref19 );
                                 desc26.putBoolean( idMkVs, false );
                              executeAction( idslct, desc26, DialogModes.NO );
                            function fillBlack(){
                            // ============Fill with Black==========================================
                              var idFl = charIDToTypeID( "Fl  " );
                                var desc11 = new ActionDescriptor();
                                 var idUsng = charIDToTypeID( "Usng" );
                                 var idFlCn = charIDToTypeID( "FlCn" );
                               var idBlck = charIDToTypeID( "Blck" );
                                desc11.putEnumerated( idUsng, idFlCn, idBlck );
                                 var idOpct = charIDToTypeID( "Opct" );
                                 var idPrc = charIDToTypeID( "#Prc" );
                                 desc11.putUnitDouble( idOpct, idPrc, 100.000000 );
                                 var idMd = charIDToTypeID( "Md  " );
                                 var idBlnM = charIDToTypeID( "BlnM" );
                                 var idNrml = charIDToTypeID( "Nrml" );
                                 desc11.putEnumerated( idMd, idBlnM, idNrml );
                              executeAction( idFl, desc11, DialogModes.NO );
                            function fillColor(){
                                 desc17.putEnumerated( idUsng, idFlCn, idClr );
                                    var idH = charIDToTypeID( "H   " );
                                     var idAng = charIDToTypeID( "#Ang" );
                                     desc18.putUnitDouble( idH, idAng, 172.232666 );
                                     var idStrt = charIDToTypeID( "Strt" );
                                     desc18.putDouble( idStrt, 35.686275 );
                                     var idBrgh = charIDToTypeID( "Brgh" );
                                     desc18.putDouble( idBrgh, 93.725490 );
                                 var idHSBC = charIDToTypeID( "HSBC" );
                                desc17.putObject( idClr, idHSBC, desc18 );
                                 desc17.putUnitDouble( idOpct, idPrc, 100.000000 );
                                 desc17.putEnumerated( idMd, idBlnM, idNrml );
                              executeAction( idFl, desc17, DialogModes.NO );
                            function deleteSelection(){
                              executeAction( idDlt, undefined, DialogModes.NO );
                            function deleteLayer(){
                               var desc25 = new ActionDescriptor();
                                   var ref18 = new ActionReference();
                                    ref18.putEnumerated( idLyr, idOrdn, idTrgt );
                                desc25.putReference( idnull, ref18 );
                              executeAction( idDlt, desc25, DialogModes.NO );
                            function addStyle(Style){
                              var idASty = charIDToTypeID( "ASty" );
                                 var desc20 = new ActionDescriptor();
                                     var idStyl = charIDToTypeID( "Styl" );
                                     ref3.putName( idStyl, Style );
                                 desc20.putReference( idnull, ref3 );
                                     var ref4 = new ActionReference();
                                     ref4.putEnumerated( idLyr, idOrdn, idTrgt );
                                 desc20.putReference( idT, ref4 );
                              try{
                              executeAction( idASty, desc20, DialogModes.NO);
                              }catch(e){}
                            function SaveAsJPEG(saveFile, jpegQuality){
                              if (doc.bitsPerChannel != BitsPerChannelType.EIGHT) doc.bitsPerChannel = BitsPerChannelType.EIGHT;
                              jpgSaveOptions = new JPEGSaveOptions();
                              jpgSaveOptions.embedColorProfile = true;
                              jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
                              jpgSaveOptions.matte = MatteType.NONE;
                              jpgSaveOptions.quality = jpegQuality;
                              activeDocument.saveAs(File(saveFile+".jpg"), jpgSaveOptions, true,Extension.LOWERCASE);
                            function SaveAsPSD( inFileName, inEmbedICC ) {
                              var psdSaveOptions = new PhotoshopSaveOptions();
                              psdSaveOptions.embedColorProfile = inEmbedICC;
                              app.activeDocument.saveAs( File( inFileName + ".psd" ), psdSaveOptions );
                            function SaveAsPDF( saveFile ) {
                              var idsave = charIDToTypeID( "save" );
                                 var idAs = charIDToTypeID( "As  " );
                                     var idpdfPresetFilename = stringIDToTypeID( "pdfPresetFilename" );
                                     desc3.putString( idpdfPresetFilename, "High Quality Print" );
                                     var idpdfCompatibilityLevel = stringIDToTypeID( "pdfCompatibilityLevel" );
                                     var idpdfoneeight = stringIDToTypeID( "pdf18" );
                                     desc3.putEnumerated( idpdfCompatibilityLevel, idpdfCompatibilityLevel, idpdfoneeight );
                                     var idpdfCompressionType = stringIDToTypeID( "pdfCompressionType" );
                                     desc3.putInteger( idpdfCompressionType, 7 );
                                 var idPhtP = charIDToTypeID( "PhtP" );
                                 desc2.putObject( idAs, idPhtP, desc3 );
                                 var idIn = charIDToTypeID( "In  " );
                                 desc2.putPath( idIn, new File( saveFile + ".pdf" ) );
                              executeAction( idsave, desc2, DialogModes.NO );
                            function align(method) {
                              var desc = new ActionDescriptor();
                              var ref = new ActionReference();
                              ref.putEnumerated( charIDToTypeID( "Lyr " ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                              desc.putReference( charIDToTypeID( "null" ), ref );
                              desc.putEnumerated( charIDToTypeID( "Usng" ), charIDToTypeID( "ADSt" ), charIDToTypeID( method ) );
                              try{
                              executeAction( charIDToTypeID( "Algn" ), desc, DialogModes.NO );
                              }catch(e){}
                            function getAlphaImageChannels() {
                              for (var n = 1; n < 999; n++) {
                              // ======Load Image n Selection===============================
                                     ref2.putName( idChnl, "Image " + n );
                              try{
                              }catch(e){
                              //alert ("n = " + n);
                              return n - 1;
                            // ======Load Alpha Channel Selection===============================
                            function loadAlpha(channel) {
                                     ref2.putName( idChnl, channel );
                            // =======linked layer Mask========================================
                            function linkedlayerMask() {
                                 var idNw = charIDToTypeID( "Nw  " );
                                 desc3.putClass( idNw, idChnl );
                                 var idAt = charIDToTypeID( "At  " );
                                     ref3.putEnumerated( idChnl, idChnl, idMsk );
                                 desc3.putReference( idAt, ref3 );
                                 var idUsrM = charIDToTypeID( "UsrM" );
                                 var idRvlS = charIDToTypeID( "RvlS" );
                                 desc3.putEnumerated( idUsng, idUsrM, idRvlS );
                              executeAction( idMk, desc3, DialogModes.NO );
                            // =======Un linked layer Mask========================================
                            function layerMask() {
                                     ref1.putEnumerated( idLyr, idOrdn, idTrgt );
                                     var idUsrs = charIDToTypeID( "Usrs" );
                                     desc3.putBoolean( idUsrs, false );
                                 desc2.putObject( idT, idLyr, desc3 );
                            function help() {
                              try{
                              var URL = new File(Folder.temp + "/PhotoCollageToolkit.html");
                              URL.open("w");
                              URL.writeln('<html><HEAD><meta HTTP-EQUIV="REFRESH" content="0; url=http://www.mouseprints.net/old/dpr/PhotoCollageToolkit.html"></HEAD></HTML>');
                              URL.close();
                              URL.execute();
                              }catch(e){
                              alert("Error, Can Not Open.");
                            // Function: initExportInfo
                            // Usage: create our default parameters
                            // Input: a new Object
                            // Return: a new object with params set to default
                            function initExportInfo(exportInfo) {
                                exportInfo.destination = new String("");
                                exportInfo.fileNamePrefix = new String("untitled_");
                                exportInfo.visibleOnly = false;
                            //    exportInfo.fileType = psdIndex;
                                exportInfo.icc = true;
                                exportInfo.jpegQuality = 8;
                                exportInfo.psdMaxComp = true;
                                exportInfo.tiffCompression = TIFFEncoding.NONE;
                                exportInfo.tiffJpegQuality = 8;
                                exportInfo.pdfEncoding = PDFEncoding.JPEG;
                                exportInfo.pdfJpegQuality = 8;
                                exportInfo.targaDepth = TargaBitsPerPixels.TWENTYFOUR;
                                exportInfo.bmpDepth = BMPDepthType.TWENTYFOUR;
                                try {
                                     exportInfo.destination = Folder(app.activeDocument.fullName.parent).fsName; // destination folder
                                    var tmp = app.activeDocument.fullName.name;
                                    exportInfo.fileNamePrefix = decodeURI(tmp.substring(0, tmp.indexOf("."))); // filename body part
                                } catch(someError) {
                            //        exportInfo.fileNamePrefix = app.activeDocument.name; // filename body part
                            // Find the location where this script resides
                            function findScript() {
                              var where = "";
                              try {
                              FORCEERROR = FORCERRROR;
                              catch(err) {
                              // alert(err.fileName);
                              // alert(File(err.fileName).exists);
                              where = File(err.fileName);
                              return where;
                            // Function for returning current date and time
                                function getDateTime() {
                                    var date = new Date();
                                    var dateTime = "";
                                    if ((date.getMonth() + 1) < 10) {
                                        dateTime += "0" + (date.getMonth() + 1) + "/";
                                    } else {
                                        dateTime += (date.getMonth() + 1) + "/";
                                    if (date.getDate() < 10) {
                                        dateTime += "0" + date.getDate() + "/";
                                    } else {
                                        dateTime += date.getDate() + "/";
                                    dateTime += date.getFullYear() + ", ";
                                    if (date.getHours() < 10) {
                                        dateTime += "0" + date.getHours() + ":";
                                    } else {
                                        dateTime += date.getHours() + ":";
                                    if (date.getMinutes() < 10) {
                                        dateTime += "0" + date.getMinutes() + ":";
                                    } else {
                                        dateTime += date.getMinutes() + ":";
                                    if (date.getSeconds() < 10) {
                                        dateTime += "0" + date.getSeconds();
                                    } else {
                                        dateTime += date.getSeconds();
                                    return dateTime;
                            // resetPrefs function for resetting the preferences
                              function resetPrefs() {
                              displayDialogs = startDisplayDialogs;
                            // CheckVersion
                            function CheckVersion() {
                              var numberArray = version.split(".");
                              if ( numberArray[0] < 9 ) {
                              alert( "You must use Photoshop CS2 or later to run this script!" );
                              throw( "You must use Photoshop CS2 or later to run this script!" );
                            // load my params from the xml file on disk if it exists
                            // gParams["myoptionname"] = myoptionvalue
                            // I wrote a very simple xml parser, I'm sure it needs work
                            function LoadParamsFromDisk ( loadFile, params ) {
                              // var params = new Array();
                              if ( loadFile.exists ) {
                              loadFile.open( "r" );
                              var projectSpace = ReadHeader( loadFile );
                              if ( projectSpace == GetScriptNameForXML() ) {
                              while ( ! loadFile.eof ) {
                              var starter = ReadHeader( loadFile );
                              var data = ReadData( loadFile );
                              var ender = ReadHeader( loadFile );
                              if ( ( "/" + starter ) == ender ) {
                              params[starter] = data;
                              // force boolean values to boolean types
                              if ( data == "true" || data == "false" ) {
                              params[starter] = data == "true";
                              loadFile.close();
                              if ( params["version"] != gVersion ) {
                              // do something here to fix version conflicts
                              // this should do it
                              params["version"] = gVersion;
                              return params;
                            // save out my params, this is much easier
                            function SaveParamsToDisk ( saveFile, params ) {
                              saveFile.encoding = "UTF8";
                              saveFile.open( "w", "TEXT", "????" );
                              // unicode signature, this is UTF16 but will convert to UTF8 "EF BB BF"
                              saveFile.write("\uFEFF");
                              var scriptNameForXML = GetScriptNameForXML();
                              saveFile.writeln( "<" + scriptNameForXML + ">" );
                              for ( var p in params ) {
                              saveFile.writeln( "\t<" + p + ">" + params[p] + "</" + p + ">" );
                              saveFile.writeln( "</" + scriptNameForXML + ">" );
                              saveFile.close();
                            // you can't save certain characters in xml, strip them here
                            // this list is not complete
                            function GetScriptNameForXML () {
                              var scriptNameForXML = new String( gScriptName );
                              var charsToStrip = Array( " ", "'", "." );
                              for (var a = 0; a < charsToStrip.length; a++ )  {
                              var nameArray = scriptNameForXML.split( charsToStrip[a] );
                              scriptNameForXML = "";
                              for ( var b = 0; b < nameArray.length; b++ ) {
                              scriptNameForXML += nameArray[b];
                              return scriptNameForXML;
                            // figure out what I call my params file
                            function GetDefaultParamsFile() {
                              //var paramsFolder = new Folder( path + "/Presets/" + gScriptName );
                              //var paramsFolder = new Folder( Folder.temp + "/JJMack's Scripts/" + gScriptName );
                              var paramsFolder = new Folder( "~/Application Data/JJMack's Scripts/" + gScriptName );
                              //alert("paramsFolder = " + paramsFolder );
                              paramsFolder.create();
                              return ( new File( paramsFolder + "/" + gScriptName + ".xml" ) );
                            // a very crude xml parser, this reads the "Tag" of the <Tag>Data</Tag>
                            function ReadHeader( inFile ) {
                              var returnValue = "";
                              if ( ! inFile.eof ) {
                              var c = "";
                              while ( c != "<" && ! inFile.eof ) {
                              c = inFile.read( 1 );
                              while ( c != ">" && ! inFile.eof ) {
                              if ( c != ">" ) {
                              returnValue += c;
                              } else {
                              returnValue = "end of file";
                              return returnValue;
                            // very crude xml parser, this reads the "Data" of the <Tag>Data</Tag>
                            function ReadData( inFile ) {
                              var c = "";
                              if ( c != "<" ) {
                              returnValue += c;
                              inFile.seek( -1, 1 );
                              return returnValue;
                            // Actions converted with X's ActionFileToJavascript
                            //==================== Set View for Place ==============
                            function SetViewforPlace() {
                              // Menu View>Fit On Screen
                                var desc1 = new ActionDescriptor();
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), cTID('FtOn'));
                                desc1.putReference(cTID('null'), ref1);
                                executeAction(cTID('slct'), desc1, DialogModes.NO);
                              // Menu View>Zoom out
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), cTID('ZmOt'));
                              // Menu View>screen Mode Full Screen With Menubar
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), sTID("screenModeFullScreenWithMenubar"));
                            //==================== Interactive Place ==============
                            function InteractivePlace() {
                              // Menu File>Place
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), cTID('Plce'));
                            //==================== Interactive Transform ==============
                            function InteractiveTransform() {
                              // Menu Edit>Free transform
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), cTID('FrTr'));
                            //==================== Set View Fit on Screen ==============
                            function SetViewFitonScreen() {
                              // Menu View>screen Mode Standard
                                ref1.putEnumerated(cTID('Mn  '), cTID('MnIt'), sTID("screenModeStandard"));
                              // Menu View>Fit on screen
                            • 11. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                              frogeyed Level 1
                              this is what happen if I put the alert line in the script:
                              And this is my layer panel:
                              • 12. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                frogeyed Level 1
                                Thank you for the script. If so, should I rasterize the image first on the file? If so, can I still maintain the layer mask so it does not go out of the border that I made?
                                I tried your script and this error message pops out:
                                • 13. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                  Something must have been messed up during paste into this jive site that is not what line 164 is... The script is one in mt Photo Collage toolkit.
                                  Photo Collage Toolkit
                                  Photoshop scripting is powerful and I believe this package demonstrates this A video showing a 5 image collage PSD template  being populates with images:
                                  The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
                                  1. Size the photo collage templates for the print size you want - width, height and print DPI resolution.
                                  2. Photo collage templates must have a Photoshop background layer. The contents of this layer can be anything.
                                  3. Photo collage templates must have alpha channels named "Image 1", "Image 2", ... "Image n".
                                  4. Photo collage templates layers above the background layers must provide transparent areas to let the images that will be placed below them show through.
                                  There are twelve scripts in this package they provide the following functions:
                                  1. TestCollageTemplate.jsx - Used to test a Photo Collage Template while you are making it with Photoshop.
                                  2. CollageTemplateBuilder.jsx - Can build Templates compatible with this toolkit's scripts.
                                  3. LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document.
                                  4. InteractivePopulateCollage.jsx - Used to interactively populate Any Photo Collage template. Offers most user control inserting pictures and text.
                                  5. ReplaceCollageImage.jsx - use to replace a populated collage image Smart Object layer with an other image correctly resized and positioned.
                                  6. ChangeTextSize.jsx - This script can be used to change Image stamps text size when the size used by the populating did not work well.
                                  7. PopulateCollageTemplate.jsx - Used to Automatically populate a Photo Collage template and leave the populated copy open in Photoshop.
                                  8. BatchOneImageCollage.jsx - Used to Automatically Batch Populate Collage templates that only have one image inserted. The Collage or Image may be stamped with text.
                                  9. BatchMultiImageCollage.jsx - Used to Automatically Batch Populate Any Photo Collage template with images in a source image folder. Easier to use than the interactive script. Saved collages can be tweaked.
                                  10. BatchPicturePackage.jsx - Used to Automatically Batch Populate Any Photo Collage template with an image in a source image folder
                                  11. PasteImageRoll.jsx - Paste Images into a document to be print on roll paper.
                                  12. PCTpreferences.jsx - Edit This File to Customize Collage Populating scripts default setting and add your own Layer styles.
                                  Documentation and Examples
                                  You can see line 164 here
                                  • 14. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                    frogeyed Level 1
                                    I downloaded the script. I have no experience before with alpha layer, which the script are asking me to make. I make an alpha mask but the script doesn't seems to recognize it.
                                    Could you kindly help me through the steps prior the scripting process?
                                    • 15. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                      Both bounds seem OK.
                                      Does the Script always fail at some particular images?
                                      Scaling the Smart Object with the replaced content would hardly seem to be more problematic than scaling a straight Layer.
                                      • 16. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                        Its alpha channel and you do have experience you just don't realize you do.  An alpha channel, a selection and a layer mask are all the same thing a selection.   Alpha channels and layer mask are nothing more than recorded selections.  If you make a selection you can record(save) it using menu select>Save selection to save it as a alpha channel or you can click on the add layer mask and sve(record) the selection as a layer mask.
                                        • 17. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                          Every Smart Object layer has as associated transform.  That transform the pixels generated for the object.    When you replace the object contents you change the generated pixels if you change the number of pixels the associated transform was not set to transform an image that size.  The transformed image will not be done the way you want but it will be done. This effect the layer size. Which will also not be the image size.   So to get  the correct image size I always transform the object size to 100% wide and 100% high.  Once I do the I can get the images actual size and then transform it to fit are image area and mask off any excess when images with different aspect ratios are selected.
                                          • 18. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                            frogeyed Level 1
                                            It used to work until it stops with that error and then it doesn't work at all now, but to show the bound alert.
                                            I am sorry for the hassle I caused. Utterly confused here.
                                            • 19. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                              frogeyed Level 1
                                              hmm, okey then. I already have my layer mask. How can I turn that into alpha 1 layer?
                                              • 20. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                                Control click on a layer with a layer mask Content icon in the layers palette that will select the layers visibility as a selection.  It load the layer mask as a selection. You can then use menu Select>Save Selection>Alpha channel name.
                                                My scripts require the Image Mapping Alpha channels be name "Image 1". "Image 2", ... "Image n".   Photoshop only supports up to 53 Alpha channels My collage templates for my scripts are limited to 53 Images.
                                                Photoshop supports up to 8000 layers you can layout 8000 image layers and all have layer mask.  You just can not use alpha channels to create the selection for the layer mask.  My PasteImageRoll could create a document like that.   I have no idea how long the script would take to create an 8000 layer document or if your machine may run out or resources first. The image layers created by that script are resized image raster layers not smart object layers like my collage script create. So the layers have much less overhead then smart Object layers the will be small compared  to object layers.
                                                My collage templates have no image layers therefore they have no image layer mask.   Populate Image smart object layer are mask using the requires Image mapping alpha channels. The alpha channels bounds are used to calculate the smart layer transform percentage and also used for positioning the placed transformed image layer.
                                                My collage templates only require a background  layer to place image over.
                                                Four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
                                                • 21. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                                  Please remove the previous alert and add
                                                  alert (theFactor)
                                                  before
                                                  What does that yield before the Script errors out?
                                                  • 22. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                                    frogeyed Level 1
                                                    Hi, I just tried that one. It pops this alert.
                                                    I think it needs a coordinate or some sort of the initial images.
                                                    • 23. Re: Batch Replace Smart Object With Different Image Quality and Sizes
                                                      The alert
                                                      alert (theFactor)
                                                      should present just the scaling factor, have you not inserted that line?
                                                      The bounds of the original SO are evaluated before the for-clause starts so the issue would probably be with the bounds of the replaced SO.
