1 Reply Latest reply on Jun 29, 2007 11:37 AM by cf_dev2
    Hidden fields that don't seem to work
    FreddyBlogs
      Using cfform structures in MX7 to pass details from 1 page to the next amending and adding details from page to page.
      So that on the second page the code is:-
      <cfform name="Flight_Refine" id="Flight_Refine" method="post" action="test_XML_Response_4.cfm">
      <input type="hidden" name="Res_Type" value="#Res_Type#" />
      <input type="hidden" name="Dep_Type" value="#Dep_Type#" />
      <input type="hidden" name="Des_Type" value="#Des_Type#" />
      <input type="hidden" name="Len_Type" value="#Len_Type#" />
      <input type="hidden" name="Ad_Num" value="#Ad_Num#" />
      Then passing the variables to test_XML_Response_4.cfm" in a repeat mechanism where the code is:-
      <cfform name="Data_Transfer" id="Data_Transfer" method="post" action="test_XML_Response_5.cfm?Ch_Passed_No=#Ch_Pass_No#&In_Passed_No=#In_Pass_No#&RDL=# RDL#">
      Although the variables are all there, when they are passed to test_XML_Response_5.cfm in the same way that they were passed to test_XML_Response_4.cfm, if I attempt to view the variables in test_XML_Response_5.cfm all I see is #variable# rather than the contents of the variable, which can only be passed as *.cfm?variable=#variable#& etc.
      Any ideas as to why this is happening.
      Thanks.
        • 1. Re: Hidden fields that don't seem to work
          cf_dev2 Level 1
          Use <cfoutput> to save the variable values rather than the literal string "#variable#". Its also good to scope your variables, like:
          #form.res_type# instead of #res_type#
          <cfoutput>
          </cfoutput>
