5 Replies Latest reply on Mar 16, 2015 11:01 AM by johnh17464058
    Failed render upon selecting "Full Resolution", but "Half Resolution" renders are successful
      I'm trying to render a comp at Best Quality+ Full Resolution. It begins rendering but it always fails at 00:00:09. When I render at Best Quality+ Half Resolution the whole comp renders successfully– no issues whatsoever.
      Also when I RAM preview at Full Res, it only previews the first 9-10 frames. When I RAM Preview at Half-Res, it previews the entire comp successfully.
      I also tried rendering a Full-Res comp from a completely different project file and it works fine on my machine.  So the problem seems to be related to this particular project file.
      Any help is greatly appreciated!
      So far I have tried all of these things in order to troubleshoot:
      - from ae, click edit>purge>all, then try the render.
      - restart ae, then try again
      - from the memory & caches preference, clear all caches, then try the render.
      - reboot the machine, then try ae.
      - run disk utility (applications/utilities) and repair permissions.
      - remove the ae prefs file (users/username/library/preferences/adobe/after effects/version#/adobe after effects (ver) prefs)
      AE Render Specs:
      Comp Size: 768x1366
      Best Quality, Full Resolution,
      Disk Cache: Read Only
      Frame Blending On for Checked Layers
      Field Render: Off
      Motion Blur: On for checked layers
      Time Span: Length of Comp
      Frame Rate: 30
      Layer Effects Used:
      FL Depth of Field
      CC Light Sweep
      CC Vector Blur
      Colorista II
      Gradient Ramp
      System specs:
      iMac (27-inch, Mid 2011)
      2.7 GHz Intel Core i5
      32 GB 1333 MHz DDR3
      AMD Radeon HD 6770M 512 MB
