1 Reply Latest reply on Feb 3, 2007 12:48 PM by Robert S
    Re: Application Crashing - Debugging Techniques?
    Level 7
      Hi
      If it's crashing when you deploy ,you know where it crashes, i mean, it
      crashes when you do a certain thing on your application doesn't it? If this is
      the case the best thing you cam do is use breakpoints on flexbuilder debugging
      to see what's happening where it crashes. If the application makes use of
      remote services, such as HTTPSEVICE,WEBSERVICE,ETC. perhaps you have forgotten
      to change localhost to the name of your server, or you can be missing the
      crossdomain.xml file on your server.
      This is all guessing since i don't know what it says when it crashes, so if
      you want you can send a link to us to see where it crashes or simply put here
      the message it gives.
        • 1. Re: Re: Application Crashing - Debugging Techniques?
          Robert S Level 1
          You misunderstood. It crashes with the Flash player by just running it outside of the Flex Builder debug state... same application, same source, same data-locations, etc.. it's not a deployment issue, it's a stability issue. The application is not specific to when it crashes... it's very much a stability thing for my application and Flash. Need debug techniques OUTSIDE of flex builder. Running the Flex Builder debug state creates a completely stable application. I can't get it to crash. But it won't be running this way in the real word.
