2 Replies Latest reply on Mar 16, 2015 5:28 PM by beh_gras_beh
    Rearranging XML structure
    beh_gras_beh Level 1
      Noob question,
      Can you rearrange an XML structure with XSLT or scripting?
      Lets say I've got an clean XML structure like this:
      <Workbook>
           <Element_A_01>
                <Element_A_02></Element_A_02>
           </Element_A_01>
           <Element_A_03></Element_A_03>
           <Element_A_04></Element_A_04>
           <Element_B_01>
                <Element_B_02></Element_B_02>
           </Element_B_01>
           <Element_B_03></Element_B_03>
           <Element_B_04></Element_B_04>
      </Workbook>
      Things got a bit messy and the structure turns suddenly to this.
      <Workbook>
           <Element_A_01>
           </Element_A_01>
           <Element_B_01>
           </Element_B_01>
      </Workbook>
      Can I go back tot the original XML structure with XSLT or scripting to find a tag and place it in the way like the original clean version?
      Greetings from Holland
        • 1. Re: Rearranging XML structure
          Dirk Becker Level 4
          Assuming the structure is within a document:
          You can export and re-import the XML, and on the way apply an XSLT. This will only strip all layout information such as text attributes, and a first XSLT will take some time.
          You can also use a script, e.g.
          var rootXE = app.activeDocument.xmlElements[0];
          var wbXEs = rootXE.evaluateXPathExpression("//Workbook");
          var wbXE = wbXEs[0];
          var a1XE = wbXE.xmlElements.item("Element_A_01");
          var a3XE = wbXE.xmlElements.item("Element_A_03");
          a3XE.move(LocationOptions.AFTER,a1XE);
          // refresh a3XE
          var a4XE = wbXE.xmlElements.item("Element_A_04");
          a4XE.move(LocationOptions.AFTER,a3XE);
          That script does not consider the spacing between A4 and B1.
          • 2. Re: Rearranging XML structure
            Thanks for the reply, it's an clear answer.
            I was hoping it could be done with XSLT and keep the text attributes, but maybe the script is an better answer I am looking for.
            The main problem is that the structure sometimes scrambled up in a nun logical way (Don't ask why, thats's a long story ).
            So what I need to do is to find the tag and place it back in the original state and it seems you're script is doing that.
            I will look in to the script tomorrow, going to sleep now (it's 01:19 here).
            Again, thanks for the help!
