• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Issue with QoQ - Posting for a developer
New Here ,
Mar 16, 2015 Mar 16, 2015
Just a heads up, I am a network guy posting for one of our developers who is too busy to take this on himself.
We were running a CF 9 production application and recently updated to CF 11. There are a few QoQ's that are now broken since the update.
I am not going to pretend like I know what I am talking about, but in CF 9, the following query returns the correct results, Toyota and Honda. In CF 11, it does not and we think its because the "TYT" and "HND" have trailing spaces.
<cfset list=queryNew("code,description","varchar,varchar")>
<cfset queryAddRow(list)>
<cfset querySetCell(list,"code","TYT ")>
<cfset querySetCell(list,"description","Toyota")>
<cfset querySetCell(list,"code","HND ")>
<cfset querySetCell(list,"description","Honda")>
<cfset querySetCell(list,"code","HMMR ")>
<cfset querySetCell(list,"description","Hummer")>
<cfset querySetCell(list,"code","CHVLT")>
<cfset querySetCell(list,"description","Chevrolet")>
Data inside the "list" table.
<table border="1" cellspacing="0" cellpadding="4">
<tr>
<td>Code</td>
<td>Code Length</td>
<td>Description</td>
</tr>
<cfoutput query="list">
<tr>
<td>#list.code#</td>
<td>#Len(list.code)#</td>
<td>#list.description#</td>
</tr>
</cfoutput>
</table>
<br /><br />
Select * from list where code='TYT' or code='HND'
<br /><br />In ColdFusion 6, the above query will give you Toyota and Honda, but in ColdFusion 11, it will not give you any results.
<br /><br />
Query Result:
<cfquery name="tyt" dbtype="query">
</cfquery>
<cfdump var="#tyt#">
Thanks in advance!
Views
585
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Mar 17, 2015 Mar 17, 2015
Have you tried redoing the querySetCell() to remove the extra space?  Or include the extra space in the SELECT query of query?
^_^
Votes
Translate
Translate
Report
Report
Advocate ,
Mar 18, 2015 Mar 18, 2015
The white spaces will cause you a problem here. When you do the query it is checking to see if code='TYT' or code='HND' which with the white space on the end is obviously false. You will either have to add the white space into the query, change the operator to 'LIKE' with a wildcard or remove it from the data. I would suggest just removing it unless its imperative you need it.
It probably worked in previous version due to a bug which was fixed in more recent versions.
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 24, 2015 Mar 24, 2015
LATEST
I think Haxtbh answers the question completely.
Votes
Translate
Translate
Report
Report
Resources
Documentation
