6 Replies Latest reply on Mar 17, 2015 9:43 AM by Dirk Becker
    [AS] storing records in the document
    David André Erichsen
      Im trying to store some PDF-export settings in the document as a label key string.
      1) How do I convert the record to one string?
      2) How do I convert the string back to a record?
      I want the return-value in this code to be "Value2".
      set myPDFsettingRecord to {PDFsettingA:"value1", PDFsettingB:"value2", PDFsettingC:"value3"}
      tell application "Adobe InDesign CC 2014"
        tell active document
        -- store string in document
        insert label key "PDFsettings" value myPDFsettingRecord as string
        -- read string in document
        set PDFsettings to extract label key "PDFsettings"
        end tell
      end tell
      set PDFsettings to split(PDFsettings, ",")
      return PDFsettingA of PDFsettings
      to split(someText, delimiter)
        set AppleScript's text item delimiters to delimiter
        set someText to someText's text items
        set AppleScript's text item delimiters to {""}
        return someText
      end split
        • 1. Re: [AS] storing records in the document
          Ronald63 Level 4
          Hello,
          Try this ...
          set theRecord to {PDFsettingA:"value1", PDFsettingB:"value2", PDFsettingC:"value3", PDFsettingD:"value4", PDFsettingE:"value5"}
          set mString to recordToString(theRecord)
          set mResult to item 2 of split(item 2 of split(mString, ","), ":")
          on recordToString(theRecord)
              try
                  return theRecord as text
              on error theError
                  set tids to text item delimiters
                  set text item delimiters to "{"
                  set a to text item 2 of theError
                  set text item delimiters to "}"
                  set b to text item 1 of a
                  set text item delimiters to "\""
                  set c to text items of b
                  set text item delimiters to ""
                  set d to "{" & (c as text) & "}"
                  set text item delimiters to tids
                  return d
              end try
          end recordToString
              return someText
          end split
          • 2. Re: [AS] storing records in the document
            David André Erichsen Level 1
            Thank you for helping me!
            As long as I can see, this convert the record to one string.
            But it does not convert it back in a variable as a record?
            • 3. Re: [AS] storing records in the document
              Ronald63 Level 4
              set mRecordKey to item 2 of split(item 1 of split(mString, ","), ":")
              set mRecordValue to item 2 of split(item 2 of split(mString, ","), ":")
              set mResult to {mRecordKey:mRecordValue}
              • 4. Re: [AS] storing records in the document
                Loic.Aigon Adobe Community Professional
                Why not use a call to js in order to take advantage of the toSource() function ?
                  set js to "app.pdfExportPresets[0].properties.toSource()"
                  set props to do script js language javascript
                  display dialog "Stored:" & props
                  set js2 to "var props = eval(" & props & "); alert(props.reflect.properties);"
                 do script js2 language javascript
                end tell
                FWIW,
                Loic
                http://www.ozalto.com
                • 5. Re: [AS] storing records in the document
                  I finally got it right:
                  Thank you guys for helping me out!
                  -- list of record to store in document:
                  -- Set records to one string
                  -- save string in active InDesign-document
                    insert label key "PDFsettings" value mString as string
                    end tell
                  end tell
                  -- return string in active InDesign-document
                    set mStringReturn to extract label key "PDFsettings"
                    end tell
                  end tell
                  --removes Curly Bracets from string and make a list of it
                  set mStringReturn to split((text 2 thru ((number of items in text of mStringReturn) - 1) of mStringReturn), ", ")
                  -- split the list into records
                  repeat with i from 1 to the number of items in mStringReturn
                    set x to split((item i of mStringReturn), ":")
                    if i is equal to 1 then
                    set mStringNew to {(item 1 of x), (item 2 of x)}
                    else
                    set mStringNew to mStringNew & {(item 1 of x), (item 2 of x)}
                    end if
                  end repeat
                  set myRecords to listToRecord(mStringNew)
                  return myRecords
                  -- Handlers:
                    try
                    on error theError
                    return d
                    end try
                  end recordToString
                  on split(someText, delimiter)
                    return someText
                  end split
                  on listToRecord(L)
                    script myScript
                    returnclass usrf»:L}
                    end script
                    return run script myScript
                  end listToRecord
                  • 6. Re: [AS] storing records in the document
                    Dirk Becker Level 4
                    @Loic - toSource() is broken for enums since CS5.
                    @David
                    Be careful with text items, some separator could also be contained in a string.
                    That listToRecord is an interesting approach.
