1 Reply Latest reply on Jan 31, 2007 10:10 PM by Tim Strickland
    using color theme once downloaded
    rossrogerb
      Hello,
      New to Kuler and Flex2. Once you download a Kuler theme how do you access it within Flex?
      Thank you,
      Roger
        • 1. Re: using color theme once downloaded
          Tim Strickland Level 1
          Currently, Flex2 does not support ASE color themes. If you create a theme in kuler that you would like to use it in your flex application, the easiest way to accomplish this is copy & paste the Hex color values for each swatch on the create page. You can then use these hex color values in a css stylesheet used in your flex application.
          Tim Strickland
          kuler senior developer
