2 Replies Latest reply on Feb 6, 2007 5:50 AM by Wal.Dain
    TabNavigator
    Wal.Dain
      I am trying to find a way of making a second row of tabs show at the top of the TabNavigator control. Without success. Is this a foolish quest or has anyone cracked it?
      Many Thanks
      Walter
        • 1. Re: TabNavigator
          batmitra Level 1
          I don't understand what you are trying to do , in design mode , i simply put a tabnavigator control and grabbed the other one and put it inside the first , it worked perfectly, here is the code generatet by flex builder
          <mx:TabNavigator x="189" y="113" width="200" height="200">
          <mx:TabNavigator width="200" height="200">
          <mx:Canvas label="Tab 1" width="100%" height="100%">
          </mx:Canvas>
          </mx:TabNavigator>
          </mx:Canvas>
          </mx:TabNavigator>
          • 2. Re: TabNavigator
            Wal.Dain Level 1
            Many thanks but not quite what I wanted. As I understand it, the tabs at the top of a tab navigator are constructed with tab bars??
            I was trying to find a way of stacking one tab bar above the other at the top of a tab navigator. Although it says in the help files that you can't nest tab navigators, apparently you can. I have taken your suggestion on board but I had to add a tab (I called it 'Other') to navigate to the nested navigator. Not quite what I had in mind but many thanks.
            Walter
