1 Reply Latest reply on Mar 17, 2015 2:53 PM by Peter Spier
    Indesign CS4
    Greg Kain
      Hello Forum,
      How can I get my Indesign to output a pdf 8.625 x 11.125, if I setup within my document to have a 0.125 bleed on the edges and it outputs the file in the size 8.75 x 11.25?
      Greg
        • 1. Re: Indesign CS4
          The size of the exported PDF is always the size of the document in Document setup, PLUS any bleed and the space required for added marks or slug. .125 bleed all around will add that .25 to the document dimension in both directions (.125 on each side), presuming you set up at 8.5 x 11....
