20 Replies Latest reply on Aug 31, 2007 8:00 PM by Newsgroup_User
    Image Map Hot Spot
    Level 7
      I am using DW8 I have an image map. If I use the square/rect tool or the
      circle tool I can get a hot spot to show. If I try to draw a polygon shape,
      I do not get the green overlay that works with the other tools.
      What am I doing wrong or is this a bug?
      Kim
        • 1. Re: Image Map Hot Spot
          Level 7
          How are you drawing the hotspot? Are you doing click:click:click:click to
          mark the apices of the polygon?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "KimMazz" <kimazzNoOil@optonline.net> wrote in message
          news:e3nr3p$oc$1@forums.macromedia.com...
          > Kim
          • 2. Re: Image Map Hot Spot
            Level 7
            actually clickity click no, only kidding. Yes I am doing click, click click
            to draw the polygon. I tried click drag click drag and it didn't work that
            way either.
            the coordinates are getting recorded, it's just not showing me the overlay.
            So, I can't select it and/or set the behavior.
            Kim
            "Murray *ACE*" <forums@HAHAgreat-web-sights.com> wrote in message
            news:e3nrn2$1i6$1@forums.macromedia.com...
            >>shape, I do not get the green overlay that works with the other tools.
            >> Kim
            • 3. Re: Image Map Hot Spot
              Level 7
              Hmmm - You are on Mac?
              news:e3nse0$2gp$1@forums.macromedia.com...
              > click to draw the polygon. I tried click drag click drag and it didn't
              > work that way either.
              > overlay. So, I can't select it and/or set the behavior.
              > Kim
              >> to mark the apices of the polygon?
              >>> Kim
              • 4. Re: Image Map Hot Spot
                Level 7
                nope, sorry PC.
                Kim
                news:e3nsi2$2lg$1@forums.macromedia.com...
                >> Kim
                >>>> Kim
                • 5. Re: Image Map Hot Spot
                  Level 7
                  Interesting, here is the generated code It seems to be placing a href tag
                  with each coordinate:
                  <map name="Map" id="Map"><area shape="poly" coords="127,57" href="#" /><area
                  shape="poly" coords="127,2" href="#" /><area shape="poly" coords="317,4"
                  href="#" /><area shape="poly" coords="318,149" href="#" /><area shape="poly"
                  coords="230,148" href="#" /><area shape="poly" coords="234,94" href="#"
                  /><area shape="poly" coords="191,78" href="#" /><area shape="poly"
                  coords="152,56" href="#" /><area shape="poly" coords="127,56" href="#"
                  /></map>
                  PC WIN XP HOME
                  KIm
                  >> Kim
                  >>>> Kim
                  • 6. Re: Image Map Hot Spot
                    Level 7
                    Ok Murray,
                    Of further interest. When I open a different page in a different site, that
                    "already" has an image map I can draw a polygon. If I open a page that "does
                    not" already have an image map I can not draw a polygon.
                    Kim
                    >> Kim
                    >>>> Kim
                    • 7. Re: Image Map Hot Spot
                      Level 7
                      Kim:
                      I have seen this happen. I have no idea why. Can you send me the page?
                      news:e3nt7e$3h8$1@forums.macromedia.com...
                      > Ok Murray,
                      > that "already" has an image map I can draw a polygon. If I open a page
                      > that "does not" already have an image map I can not draw a polygon.
                      > Kim
                      >>> Kim
                      >>>>>the circle tool I can get a hot spot to show. If I try to draw a
                      >>>>>polygon shape, I do not get the green overlay that works with the other
                      >>>>>tools.
                      >>>>> Kim
                      • 8. Re: Image Map Hot Spot
                        Level 7
                        I found that if I go to the map in code view and delete all the code except
                        for the coordinates then it shows the overlay. I will send you the file.
                        Kim
                        news:e3nvs3$755$1@forums.macromedia.com...
                        > Kim:
                        >> Ok Murray,
                        >> Kim
                        >>>> Kim
                        >>>>> click:click:click:click to mark the apices of the polygon?
                        >>>>>>other tools.
                        >>>>>> Kim
                        • 9. Re: Image Map Hot Spot
                          Level 7
                          Is it a templated page? Is the image with the hot spots in a "layer"?
                          James M. Shook
                          http://www.jshook.com
                          • 10. Re: Image Map Hot Spot
                            Level 7
                            I can't reproduce it with the page you sent me, Kim.
                            news:e3o180$8vm$1@forums.macromedia.com...
                            > Kim
                            >> Kim:
                            >>> Ok Murray,
                            >>> Kim
                            >>>>> Kim
                            >>>>>>>other tools.
                            >>>>>>> Kim
                            • 11. Re: Image Map Hot Spot
                              Level 7
                              James,
                              No and no.
                              Kim
                              "James Shook" <jshook@dont_mail.com> wrote in message
                              news:e3o1m5$81j$3@forums.macromedia.com...
                              > James M. Shook
                              • 12. Re: Image Map Hot Spot
                                Level 7
                                Murray,
                                Which would mean that it's my PC bug? How can it be fixed then?
                                Kim
                                news:e3o1ug$9ss$1@forums.macromedia.com...
                                >>except for the coordinates then it shows the overlay. I will send you the
                                >>file.
                                >> Kim
                                >>> Kim:
                                >>>> Ok Murray,
                                >>>> Kim
                                >>>>>> click click to draw the polygon. I tried click drag click drag and it
                                >>>>>> didn't work that way either.
                                >>>>>> Kim
                                >>>>>>> Technotes
                                >>>>>>>>other tools.
                                >>>>>>>> Kim
                                • 13. Re: Image Map Hot Spot
                                  Level 7
                                  To be honest, I'm not sure. I have submitted it as a bug in the past, but
                                  without steps to make it reproduce every time, it's hard to have someone fix
                                  it.
                                  news:e3o290$ad0$1@forums.macromedia.com...
                                  > Murray,
                                  > Kim
                                  >>>file.
                                  >>> Kim
                                  >>>> Kim:
                                  >>>> page?
                                  >>>>> Ok Murray,
                                  >>>>> Kim
                                  >>>>>>> it didn't work that way either.
                                  >>>>>>> Kim
                                  >>>>>>>> Technotes
                                  >>>>>>>>>or the circle tool I can get a hot spot to show. If I try to draw a
                                  >>>>>>>>>other tools.
                                  >>>>>>>>> Kim
                                  • 14. Re: Image Map Hot Spot
                                    Level 7
                                    Hmm, so you're saying that you can see the overlay when you draw a poly
                                    shape?
                                    Kim
                                    news:e3o2k9$as4$1@forums.macromedia.com...
                                    > fix it.
                                    >> Murray,
                                    >> Kim
                                    >>>>the file.
                                    >>>> Kim
                                    >>>>> Kim:
                                    >>>>> page?
                                    >>>>>> Ok Murray,
                                    >>>>>> site, that "already" has an image map I can draw a polygon. If I open
                                    >>>>>> a page that "does not" already have an image map I can not draw a
                                    >>>>>> polygon.
                                    >>>>>> Kim
                                    >>>>>>> Technotes
                                    >>>>>>>> Kim
                                    >>>>>>>>> Technotes
                                    >>>>>>>>>>a polygon shape, I do not get the green overlay that works with
                                    >>>>>>>>>>the other tools.
                                    >>>>>>>>>> Kim
                                    • 15. Re: Image Map Hot Spot
                                      Level 7
                                      Yes. Every time, on every image (placeholder).
                                      news:e3o2ml$av2$1@forums.macromedia.com...
                                      > shape?
                                      > Kim
                                      >> but without steps to make it reproduce every time, it's hard to have
                                      >> someone fix it.
                                      >>> Murray,
                                      >>> Kim
                                      >>>>>the file.
                                      >>>>> Kim
                                      >>>>>> Kim:
                                      >>>>>> page?
                                      >>>>>>> Ok Murray,
                                      >>>>>>> open a page that "does not" already have an image map I can not draw
                                      >>>>>>> a polygon.
                                      >>>>>>> Kim
                                      >>>>>>>> Technotes
                                      >>>>>>>>> Kim
                                      >>>>>>>>>> Technotes
                                      >>>>>>>>>>>the other tools.
                                      >>>>>>>>>>> Kim
                                      • 16. Re: Image Map Hot Spot
                                        waywest
                                        I'm having the same problem with the polygon tool on a Mac (10.4) and a PC (XP), so it's not platform specific. Rectangle and circle work.
                                        • 17. Re: Image Map Hot Spot
                                          hwatson2
                                          I know this thread is over a year old but I just fought my way through this one and found a solution. Actually, I also fought it three years ago on Dreamweaver MX but forgot the solution.
                                          The only way I was able to make it work was to remove any alignment from the image. This includes DIV tags, tables and alignment settings on the img statement. What I did was to move the image from an aligned table to just below the Body tag. The polygon tool worked perfectly then. Once I finished all of the hotspots, I moved the image back to its original location inside the table and reestablished the alignments and everything works fine.
                                          The real problem is that dreamweaver will not create a polygon hotspot on an image that has alignment settings.
                                          Bug in Dreamweaver.
                                          • 18. Re: Image Map Hot Spot
                                            paros375
                                            This bug is now fixed in 8.0.2 upgrade.
                                            • 19. Re: Image Map Hot Spot
                                              steve_ely
                                              I am using Dreamweaver in the cs3 suite. I had some pages that i created in a previous version of image ready in which I had image maps on several locations on the page. However, when i open those files in the new photoshop and save them for web when I open them in dreamweaver all the image map info. is no longer there. Can someone please give some tips or advise on this?
                                              • 20. Re: Image Map Hot Spot
                                                Level 7
                                                > on the page.
                                                What file format are these files? html and images? or only .psd? or ?
                                                Can you upload the html files you opened in dreamweaver to someplace and
                                                give the url address to them so the code can be seen?
                                                also- it looks like you did a 'me too' reply to an old post?
                                                Alan
                                                Adobe Community Expert, dreamweaver
                                                http://www.adobe.com/communities/experts/
