0 Replies Latest reply on Feb 9, 2007 6:40 AM by jettix
    Loading a remote SWF via SWFLoader Issue
    jettix
      I have a simple flex app which loads an external XML into an arrayCollection using HTTPService send method. This works fine as both a stand-alone, or when loaded into it's parent as a LOCAL file via the SWFLoader tag. However, when I place this child file onto a remote server and try to load it into the parent which resides on my desktop, the ArrayCollection default resultFormat of the send method triggers the following runtime error (listed below). I don't think it's a sandbox issue because when I change result format to e4x, it works fine remotely. I've been hitting a wall on this for days now... Any insight would be greatly appreciated and thanks to all in advance!!!
      PARENT SWF (resides on local desktop)
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="vertical" initialize="initData()">
      <mx:Script>
      <![CDATA[
      public var baseURL:String;
      public function initSWF(swfURL:String):void {
      remote_swf.load(swfURL);
      public function initData():void
      baseURL = " http://blahblahblah";
      Security.allowDomain(baseURL);
      </mx:Script>
      <!-- WORKS when loading child swf LOCALLY -->
      <mx:Button label="Load LOCAL SWF APP" click="initSWF('remoteSWF.swf')"/>
      <!-- DOES NOT WORK when loading child swf REMOTELY -->
      <mx:Button label="Load REMOTE SWF APP" click="initSWF(' http://blahblahblah/remoteSWF.swf')"/>
      <!-- LOADER -->
      <mx:SWFLoader height="100%" width="100%" id="remote_swf" autoLoad="false" visible="true" scaleContent="false"/>
      </mx:Application>
      CHILD SWF (resides on remote server)
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="getXMLData()">
      <mx:HTTPService id="myTeams" url=" http://blahblahblah/xml/myXML.xml"/>
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      import mx.collections.ArrayCollection;
      public function getXMLData():void
      Alert.show(Security.sandboxType);
      myTeams.send();
      </mx:Script>
      <mx:Label text="THIS IS THE LOADED SWF WHICH HAS JUST PERFORMED A SEND ON HTTP SERVICE TO CREATE ARRAY COLLECTION"></mx:Label>
      </mx:Application>
      ------------ RUNTIME ERROR ---------------------------------
      ArgumentError: Error #1063: Argument count mismatch on Object/ http://adobe.com/AS3/2006/builtin::hasOwnProperty(). Expected 0, got 2.
      at mx.rpc.xml::SimpleXMLDecoder/decodeXML()
      at mx.rpc.http::HTTPService/ http://www.adobe.com/2006/flex/mx/internal:rocessResult()
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::resultHandler()
      at mx.rpc::Responder/result()
      at mx.rpc::AsyncRequest/acknowledge()
      at :irectHTTPMessageResponder/completeHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunctio n()
      at flash.events::EventDispatcher/dispatchEvent()
      at flash.net::URLLoader/flash.net:URLLoader:nComplete()
