• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Need help to set up multilingual project
New Here ,
Mar 18, 2015 Mar 18, 2015
Hi guys,
i'm relatively new to RH and i have a help system to create in 3 languages (English, French, German) and in many flavors. This is for an online application with multiple user roles. The trick is that the help system is supposed to follow the hirearchy of privileges, that is, a low-level user should not see the pages covering the system settings or the admin dashboard. When a user signs in, the app will load a help file based on the respective user roles and locale settings.
My dev guy is going to provide me with an xml file that contains the existing user roles and privileges, and the outputs should be generated accordingly. The SSL of our choice is responsive HTML5. I'm guessing this is possible to do in RH11, tho frankly i have no idea where to start. What would be the proper approach to set up this project? I've created less convoluted user guides earlier and i was happy with the results but am stuck with this one.
Any help is much appreciated.
Views
213
Translate
Translate
Report
Report
Community guidelines
community guidelines
You can customize the content as per your need (admin version , user version) and then apply conditional built tags which will apply a condition on the output you generate .
For example if you want certain content not to be available in admin version you can create a conditional built tag and apply it.
You can even choose advanced conditional built tag and apply conditions like 'OR, NOT, AND'.
The following links will be helpful for you:
Adobe RoboHelp 11 * Conditional build tags
Adobe RoboHelp 11 * Conditional build tag expressions
http://help.adobe.com/en_US/robohelp/robohtml/WS454F21D1-1010-4fa6-99D4-BF9163E4D78C.html
Votes
Translate
Translate
Votes
Translate
Translate
Report
Report
New Here ,
Mar 19, 2015 Mar 19, 2015
Hi Anvinder,
thanks much for your help. This conditional build tag feature is just what i need. I missed to look into it before, though i was aware of its existence.
Votes
Translate
Translate
Report
Report
Community Expert ,
Mar 21, 2015 Mar 21, 2015
LATEST
Is it important that some users do not see the additional information? In most apps seeing the information would not enable them to carry out the procedures as permissions should have been set up to prevent that.
You could generate one output with books in the TOC for each user type or even create Content Categories. The latter would open the help with the default category and users could then choose their category. The content would then be limited to their topics. That does not and cannot stop them viewing the other categories.
Your way requires different outputs and the developers then have to figure out who is accessing the help and call the appropriate version.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
