1 Reply Latest reply on Mar 18, 2015 7:33 PM by A.T. Romano
    blu-ray discに書き込みができず。
    正斉95995988
      エラーメッセージ(何らかの問題によりblu-rayを正常に書き込みません。)
      次の場所に保存されたisoイメージを使用して書き込んでください。これを使用しても書き込みができません。
        • 1. Re: blu-ray discに書き込みができず。
          A.T. Romano Level 7
          95995988
          What version of Premiere Elements and on what computer operating system is it running?
          For now I will assume Premiere Elements 13/13.1 on Windows 7, 8, or 8.1 64 bit computer.
          What is the problem with the Publish+Share/Disc/Blu-ray burn to disc....
          a. transcoding errors
          b. failures at encoding menus, encoding media, compiling, or at the actual burn part?
          When your Blu-ray disc is in the burner tray, in the Premiere Elements burn to dialog, what does the Quality Area show for Space Required and Bitrate with
          and without a check mark next to Fit Content to Available Space?
          The 13.1 Update has a feature which directs you to the .iso image if the burn to disc fails.
          But, there are problems with that. If the file size of the .iso image is over 1 GB and you put that .iso
          image on Blu-ray disc, the player will not recognize it.
          ATR Premiere Elements Troubleshooting: PE 13: ISO Image File Size Issue
          So let us see if we can find the problem with the Publish+Share/Disc/Blu-ray burn to disc.
          Please supply more information for us to help you.
          Thank you.
          ATR
