1 Reply Latest reply on Mar 19, 2015 1:04 AM by Willi Adelberger
    remove text box and contents from entire document
    Wali60 Level 1
      I have an ID document that I need to remove a text box and its contents. The text box appears 10 times on each page. Is there a way to do this or do I have manually go through each page.
      Thanks for any help in advance.
        • 1. Re: remove text box and contents from entire document
          I don't know how your document is set up and if pages are added if overflow text is available.
          If your text is linked, go first into one of the frames with the text curser, select all. Then go through select all with the selection tool and press delete.
          If your frames are not linked, select all on each page with the selection tool and delete.
          If your frames come from the master, delete them on the master. Overrides (which should not be done on pages) you have to delete separately.
