• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Publishing not working
Guest
Feb 07, 2007 Feb 07, 2007
I'm sure ths is a dumb question and I'm going to kick myself when someone posts a simple explanation, but my project suddenly refuses to publish to my server. The primary layout is webhelp and I haven't changed anything in the publish dialogue (e.g.the server name is checked.). It generates without any problem, but nothing happens when I click 'Publish': no error message, nothing.
- John
Views
464
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 07, 2007 Feb 07, 2007
Trying amending the target to somewhere on your hard disk. That will tell you whether the problem is with RoboHelp (if that also fails) or is a network issue (if it publishes OK to your hard disk).
If it works locally but not on the network, next try another location on the network, same server, just another folder.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hi all
In addition to my esteemed colleague's words of wisdom, it seems I recall a recent thread where it was discovered a file named "Thumbs.db" was among the mix and was the culprit. I'd also check the WebHelp output folder for the existence of these files (you may find one in each or several folders) and delete it.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Enthusiast ,
In this situation I would test to see if the layout file is corrupted in some way.
If you are using the WebHelp default layout, create a new one under another name and see if the new one will publish.
If you're using a custom WebHelp layout, delete it in RH, close the project , make sure the corresponding *.ssl file is gone from the project folder, open the project, and create a new layout under a different name (just in case RH has saved the old name in some dark corner of the database).
Harvey
Votes
Translate
Translate
Report
Report
Guest
Feb 11, 2007 Feb 11, 2007
Thanks Peter, Rick and Harvey. This time it turned out to be a server problem. I should have checked this first, but I had a similar problem a while ago, and Rick's advice about the offending 'thumbs.db' file was the solution at that time.
John
Votes
Translate
Translate
Report
Report
New Here ,
Aug 22, 2007 Aug 22, 2007
LATEST
Ah, the value of searching for an old thread! I am having the same problem, and this is helping. As a result of all the info here I've been able to narrow it down to what I think is a server problem. Crossing my fingers...
thanks all!
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
